Buying a used UTEC...
what should i expect to receive with a used UTEC w/switcher? does a CD come with it for the datalogging? the PC connetion cable? anything would be helpfull.
im not a evo noob, but just a utec noob. Justin
Nothing is required except a serial cable.. There's no CD because there's no software required other than what your PC already has..
Go to the TurboXS website and download the documentation for the EVO UTEC.. also when you get it, see what version of the firmware it has.. I would reflash it regardless so it resets all of the maps and parameters that might have been set that your not aware of.
Originally Posted by gestalt
I also just bought a used UTEC with switch. A little nervous about buying used, but I could not pass up the deal.
Originally Posted by jong
How do you go about reflashing the UTEC? I also bought a used one, and I'm not exactly sure what I have to have done before I go in to get it tuned. I read the manual and the install seems really easy, and even the basic start-up/PC procedures, but I didn't notice a mention of "re-flashing." Thanks.
I just got the UTEC installed, and i have been working with the map that the first owner had. im alittle confused with tuning. im use to the s-afcII. the problem for me is the load % in the tuning. if anyone has any advise, i could really use it. btw, feel free to call. 661-978-4898 thanks justin
Originally Posted by BSREVOLUTION
Luis, Thank you so very much for all your help. I found a new best friend.
Justin,
Your Welcome. Whatever questions you need answered, just give me a ring
. Lu
