Utec timing stage 2 -100?
Utech timing: I'm trying to figure out why Turbo xs wants you to use -100 on the stage2 map. Is there something special about -100? I can't get my utec to accept -100 only -99 and it runs like crap on that. It seems to like +20? just trying to understand how all this is working so I don't mess anything up to bad.
TurboXS wants:
Timing Map
[-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100]
[-100] [17.2] [15.2] [13.2] [12.2] [10.7] [10.7] [10.7] [10.7] [10.7] [10.7]
[-100] [16.8] [13.8] [11.8] [10.8] [9.3] [9.3] [9.3] [9.3] [9.3] [9.3]
[-100] [15.8] [12.8] [10.8] [9.8] [8.3] [8.3] [8.3] [8.3] [8.3] [8.3]
[-100] [14.8] [11.8] [9.8] [8.8] [7.3] [7.3] [7.3] [7.3] [7.3] [7.3]
[-100] [14.8] [12.8] [10.8] [9.8] [8.3] [8.3] [8.3] [8.3] [8.3] [8.3]
[-100] [13.8] [11.8] [9.8] [8.8] [7.3] [7.3] [7.3] [7.3] [7.3] [7.3]
[-100] [12.8] [10.8] [8.8] [7.8] [6.3] [6.3] [6.3] [6.3] [6.3] [6.3]
[-100] [12.8] [9.8] [8.8] [7.8] [6.3] [6.3] [5.8] [5.8] [5.8] [5.8]
[-100] [12.6] [9.6] [8.6] [7.6] [6.1] [5.7] [4.9] [4.9] [4.9] [4.9]
[-100] [13.1] [11.1] [10.1] [9.1] [7.6] [7.1] [5.8] [5.8] [5.8] [5.8]
[-100] [13.2] [11.2] [10.2] [9.2] [7.7] [7.2] [6.2] [6.2] [6.2] [6.2]
[-100] [12.5] [10.5] [9.5] [8.5] [7] [7] [6.3] [6.3] [6.3] [6.3]
[-100] [12.7] [10.7] [9.7] [8.7] [7.2] [7.2] [7.2] [7.2] [7.2] [7.2]
[-100] [9] [7.5] [7.5] [7.5] [7.5] [7.5] [7.5] [7.5] [7.5] [7.5]
[-100] [9.7] [8.2] [8.2] [8.2] [8.2] [8.2] [8.2] [8.2] [8.2] [8.2]
[-100] [9.8] [8.3] [8.3] [8.3] [8.3] [8.3] [8.3] [8.3] [8.3] [8.3]
[-100] [11.7] [11.7] [11.7] [11.7] [11.7] [11.7] [11.7] [11.7] [11.3] [11.3]
[-100] [12.3] [12.3] [12.3] [12.3] [12.3] [12.3] [12.3] [12.3] [11.5] [11.5]
[-100] [13.9] [13.9] [13.9] [13.9] [13.9] [13.9] [13.9] [13.9] [13.1] [13.1]
[-100] [15.7] [15.7] [15.7] [15.7] [15.7] [15.7] [15.7] [15.7] [15.7] [15.7]
[-100] [16.2] [16.2] [16.2] [16.2] [16.2] [16.2] [16.2] [16.2] [16.2] [16.2]
[-100] [16.5] [16.5] [16.5] [16.5] [16.5] [16.5] [16.5] [16.5] [16.5] [16.5]
[-100] [17.6] [17.6] [17.6] [17.6] [17.6] [17.6] [17.6] [17.6] [17.6] [17.6]
[-100] [17.8] [17.8] [17.8] [17.8] [17.8] [17.8] [17.8] [17.8] [17.8] [17.8]
[-100] [18.5] [18.5] [18.5] [18.5] [18.5] [18.5] [18.5] [18.5] [18.5] [18.5]
[-100] [20.8] [20.8] [20.8] [20.8] [20.8] [20.8] [20.8] [20.8] [20.8] [20.8]
TurboXS wants:
Timing Map
Originally Posted by dipdm
I did leave it as ecu but the car ran bad with 0 or ecu in that field. I ended up with +20 in those fields it seems to run ok with no lean spots egts about 750-820c
I bought this car used from a bank they knew nothing about it: This is just what I could see has been done
Mods:
Down pipe, no cat full 3in exhaust
K&N air cleaner
Utec 1.7
Techedge Wideband
twin disk Exedy clutch
I will log some data tonight and post them tonight or tomorrow.
Mods:
K&N air cleaner
Utec 1.7
Techedge Wideband
TurboXS wants:
Timing Map
TurboXS wants:
Timing Map
Yah -100 is the "Map file" representation of an ECU Passthrough.. it means the stock ECU is operating on that load cell..
You can't just Edit the text maps.. it has a checksum to prevent it from getting corrupt.. In the Hyperterminal Map editor.. type E for ECU... -100 or 100 won't work since they don't represent anything.. But -100 is a reserved number to represent the ECU passthrough.
and using -99 is basically killing your ignition, 99 degrees before TDC... You'd likely trigger a check engine light if you did that..
