UTEC detonation QUESTION
Old Jan 31, 2005 | 05:53 PM
superman105's Avatar
I have a 2005 Evo GSR
just installed UTEC today
have detonation problem on 2 or 3rd gear
the Cell light would start to flash around 3k - 4k rpm
and pass 4k it will stop
I'm using the Turbo XS Stage 1 map. (no changes)
what should I do at this point
how many degrees retard should do to the timeing at 3k-4k RPM ?
Old Jan 31, 2005 | 06:44 PM
MalibuJack's Avatar
If you don't have a wideband its difficult to know why your getting detonation.. Is your boost spiking, is there too aggressive timing, is it too lean.. you need to log data with a wideband installed to be certain.
HOWEVER, I suspect its a combination of boost and a lean condition which means you should be adding fuel, but you really need to do this with adequate instrumentation.
Old Jan 31, 2005 | 06:45 PM
MalibuJack's Avatar
I would say that for the time being, you should be running in MAP0 and logging lots of data.. then if you don't have the wideband and experience, you should have it tuned by a tuner.
Old Feb 1, 2005 | 09:00 AM
soule77's Avatar
^What he said. I don't know if you have any Mods but Map 1 is designed for a stock evo. I have been using it for a couple of weeks w/ no issues so a knock in map 1 on a stock car could be indicative of another problem altogether. I really don't have the technical knowledge to speculate though. Be careful... a bad knock can ruin your day.
https://www.evolutionm.net/forums/sh...d.php?t=108039
https://www.evolutionm.net/forums/sh...d.php?t=108337
Old Feb 1, 2005 | 09:19 AM
tks for your post Malibu
I have now set to Map 0 and there is no issue
today I setup my wideband
Old Feb 1, 2005 | 09:50 AM
Malibu
at which TPS% does map0 goes into OLF ?
why is the MAF HZ different than Mod MAF HZ in Map 0 ?
tks
Old Feb 1, 2005 | 11:37 AM
TampaTurbo's Avatar
Originally Posted by superman105
Malibu
tks
Map 0 is pass thru. There is no open loop feature unless you switch to a map > 0. Otherwise its normally 35% TPS or 5000rpms, whichever comes first.
Old Feb 1, 2005 | 12:00 PM
MalibuJack's Avatar
Generally you see a slight lag in the signal of the Mod Maf reading from the MAF reading.. if the values are significantly different, then it could be scaling is enabled.. But since your in MAP0, its really just the lag of the signal.. if you look the value of the MOD MAF is generally one "Step" behind.. It has no affect on the engines performance unless the "Value" is significantly different for a long duration..
Old Feb 1, 2005 | 12:18 PM
Thumbs up
tks for the reply guys
