What the hell?
Old Mar 16, 2005 | 07:01 PM
pyrovice's Avatar
What the hell?
My car has been at Godspeed for 24 days getting parts installed and tuned, the parts have been installed for awhile and the tuner says the new version of power fc that i have, dejettro or something I can't recall, doesn't work with his old power fc maps. He says he needs to get them from New Zealend, anybody else have this problem?
Old Mar 17, 2005 | 08:26 PM
pyrovice's Avatar
bumpity?
Old Mar 20, 2005 | 10:34 AM
blueo4's Avatar
why godspeed! they are expensive and always full of excuses!
You should have tried Payn Performance down by Oakland or Troy area if I recall their location correctly.
always interrigate godspeed before you even let them pump your gas!
Old Mar 21, 2005 | 08:02 AM
Guru's Avatar
We got it working. Datalogit was a bit slow in getting us the software we needed but all is good and car is running fantastic. We now have the dataologit software for all USDM EVO VIII Power FC's as well as RX7's, Hondas and SR20's.
Old Mar 27, 2005 | 05:30 AM
gvr4v's Avatar
is there any direction or information on the Datalogit software. I have it for mine (Evo7-LHD) and it did not come with any. Sould I call the place where I purchased from and ask them. They dont know that much about our Evo's (RX-7). I got instructions on how to install it. The car is running though, after switching the #8 and #22 wires?? Also my check engine lightis on for some reason too.
Any help would be great.
Thanks, Victor
Old Mar 31, 2005 | 04:56 PM
Guru's Avatar
Victor look in the Etc menu under sensor check. It will tell you why the CEL is on. If you disconnected your MAP it will throw an MDP code. Just plug it in and zip tie it in there. It will not be used but you still need to plug it in. If you have Datalogit you can e-mail datalogit in New Zealand and they will give you access to their message board. It is private board for owners of the Dayalogit only. Very good info in there.
siduolocin
Oct 9, 2011 11:58 PM
evotuner04
Dec 9, 2007 06:43 PM
David Buschur
49
Mar 22, 2007 07:32 PM
Miralution
Dec 19, 2006 03:33 AM
rt turbo
13
Nov 19, 2004 09:52 AM
