Using TXS's Stg 2 map safe for daily driving?
Old Mar 21, 2005 | 09:47 AM
ct9a gsr's Avatar
Just curious... I've had my car fully tuned for the mods it has (buschur racing stage 2 + FMIC) and on 93 octane. On this map, my car produces about 11 mpg... and that's just driving normally, not going WOT everywhere. When driving normally on the TXS's factory stage 2 map, I get about 19 mpg. My question is, would it be safe to drive on this stage 2 map for daily driving as long as I don't go WOT or into high boost? So far, I've had no signs of knock or any problems dong so.
Old Mar 21, 2005 | 11:26 AM
SoR's Avatar
SoR
You should be fine since unless you're sitting on the gas pedal you're mostly in cruising mode.
I would just default to wastegate boost to be safe.
