Rich spot between 4-5k
Anyone else have this rich problem occuring in between 4-5k?
I have some logs.
3635 +26.6 324 26 00 00 +30.7 12.7 ECU. +1.0 ECU. 348 14.74
3827 +26.8 435 32 10 00 +25.9 21.6 +14.0 +13.0 ECU. 568 14.70
4030 +26.8 609 43 10 00 +15.6 31.1 +9.6 +20.0 ECU. 786 14.58
4224 +26.8 793 49 10 00 +9.6 39.7 +10.4 +20.0 ECU. 1008 13.59
4610 +27.0 1094 60 10 00 +5.9 62.3 +10.7 +20.0 ECU. 1288 11.58
4844 +27.0 1291 67 30 00 +0.0 68.3 +9.9 +10.0 ECU. 1470 10.09
5341 +27.2 1436 65 40 00 +5.1 72.5 +10.6 +10.0 ECU. 1572 9.21
5963 +26.8 1612 64 60 00 +16.2 63.8 +13.5 -14.0 ECU. 1420 9.39
6410 +26.8 1689 67 70 00 +14.1 76.3 +15.5 +0.1 ECU. 1736 10.87
6887 +26.8 1736 69 80 00 +17.4 79.8 +17.3 +2.9 ECU. 1712 11.77
6706 +26.8 138 15 00 00 +38.5 9.3 ECU. +0.0 ECU. 131 11.11
6253 +26.8 96 8 00 00 +38.4 7.3 ECU. +0.0 ECU. 71 11.14
4095 +27.2 729 34 10 00 +9.9 37.6 +9.7 +20.0 ECU. 912 13.65
4130 +27.0 751 35 10 00 +7.9 38.4 +9.8 +20.0 ECU. 980 13.65
4295 +27.0 1008 42 10 00 +5.4 54.1 +10.4 +20.0 ECU. 1179 11.87
4504 +27.0 1141 58 20 00 +1.2 66.4 +8.9 +20.0 ECU. 1344 10.43
4734 +26.8 1265 73 40 00 +4.3 65.4 +9.0 +10.0 ECU. 1445 9.77
5035 +26.6 1369 88 50 00 +3.8 61.8 +10.2 -0.1 ECU. 1404 9.58
5307 +26.8 1453 100 60 00 +10.0 62.5 +10.7 -6.2 ECU. 1381 9.93
5621 +26.6 1567 100 70 00 +9.0 72.5 +11.6 +0.4 ECU. 1677 10.81
5868 +26.8 1592 100 70 00 +9.1 76.6 +13.0 +1.7 ECU. 1724 11.58
6116 +27.0 1628 100 80 00 +9.8 77.9 +14.8 +3.4 ECU. 1689 11.12
6410 +27.0 1683 100 90 00 +14.5 73.8 +15.7 -3.3 ECU. 1623 10.58
6626 +27.0 1700 100 90 00 +17.5 76.3 +16.7 -3.2 ECU. 1700 10.74
5482 +27.2 1483 100 40 00 +5.1 77.4 +10.9 +10.0 ECU. 1666 10.29
5546 +27.2 1510 100 70 00 +15.3 69.4 +11.3 -0.1 ECU. 1633 9.84
5649 +27.2 1506 100 80 00 +7.2 76.1 +11.7 +7.3 ECU. 1724 11.05
5688 +27.2 1529 100 80 00 +6.2 75.8 +11.8 +6.7 ECU. 1623 11.73
5128 +27.0 948 100 10 00 +12.1 58.6 +11.0 +20.0 ECU. 1275 13.92
4761 +27.2 1272 100 10 00 +2.8 72.1 +10.7 +14.0 ECU. 1506 12.11
5307 +27.2 1543 100 30 00 +1.9 76.9 +10.8 +5.2 ECU. 1736 9.90
5678 +27.2 1474 100 60 00 +13.3 61.0 +11.3 -12.5 ECU. 1388 9.45
5910 +27.2 1577 100 70 00 +12.3 74.7 +13.0 +1.8 ECU. 1736 10.76
6093 +27.2 1597 100 80 00 +9.2 78.5 +14.5 +6.4 ECU. 1612 11.73
6349 +27.2 1655 100 80 00 +12.3 78.3 +15.6 +3.3 ECU. 1785 10.78
6600 +27.2 1689 100 90 00 +15.7 75.9 +16.5 -1.8 ECU. 1689 10.55
6816 +27.4 1718 100 90 00 +18.5 76.9 +17.2 -3.2 ECU. 1677 10.89
7047 +27.2 1773 100 90 00 +21.5 78.5 +17.4 -2.9 ECU. 1677 11.17
7407 +27.4 415 79 100 00 +23.2 35.4 +17.4 +4.0 ECU. 132 11.23
5367 +27.0 1483 100 20 00 +1.6 86.0 +11.0 +20.0 ECU. 1700 11.65
5518 +27.2 1474 100 50 00 +9.1 47.5 +10.8 -31.1 ECU. 1046 9.84
5649 +27.2 1515 100 70 00 +10.2 70.9 +11.7 +0.5 ECU. 1428 10.43
5827 +27.0 1543 100 80 00 +8.9 77.5 +12.4 +7.4 ECU. 1724 11.53
5963 +27.0 1582 100 80 00 +9.1 78.1 +13.4 +9.2 ECU. 1736 11.01
6071 +26.8 1633 100 80 00 +9.9 79.6 +14.2 +7.6 ECU. 1838 10.55
6184 +27.0 1639 100 80 00 +12.3 77.2 +14.9 +5.2 ECU. 1785 10.48
Don't worry about the lean spots, those are gear changes.
There are a few tests i will perform on the car to see if the JDM MR DV is leaking or not, but i wanted to know if anyone else had this problem.
I have some logs.
He just put in 680cc injectors and i was just tuning it out manually rather than set the utec to adjust globally. I did take out fuel, up to -30 when everything else is small. Just wondering if anyone else has this problem. I'm going to boost leak test the car because the bov may be leaking air back into the intake causing the car to misfire and run rich. The maf readings on the first log spike up very quickly. I don't think it was a boost spike because the peak on the boost controller said 20.3 pounds.
what are you talking about, "manually" and "globally"?
You shoulod be tuning for each load site and rpm.
-30 seems like alot. The most I have is a 10% change. I see you have as much as +20% and -14%.
manually is going into the maps and changing the values by hand. Globally is going into the utec injector scaling options. I only put +20 in the 10 and 20 load columns because i thought the car was going lean getting back into gear. But i guess the wideband is slow or isn't one to one with the datalog.
swapped out back to the stock bov and the hz are now smooth. No more misfires or rich spots. There are some discrepancies with the hz here and there, and some strange knock. I suspect the cam gears. I'll post up some logs later when i take them off the laptop.
3202 +26.6 44 0 00 00 +18.6 4.5 ECU. +0.0 ECU. 40 14.37
2610 +26.8 312 31 10 00 +20.5 13.0 +22.8 -4.0 ECU. 279 14.30
2673 +27.0 314 38 10 00 +14.2 13.0 +11.1 +2.3 ECU. 308 15.12
2730 +26.8 352 60 10 00 +16.2 14.6 +10.7 +5.0 ECU. 361 14.96
2858 +27.0 389 86 10 00 +14.6 16.9 +10.5 +5.0 ECU. 431 13.97
2944 +27.0 431 100 10 00 +13.5 18.7 +10.2 +5.0 ECU. 450 13.39
3103 +26.8 502 100 10 00 +10.4 21.9 +9.9 +7.0 ECU. 588 12.81
3297 +27.0 576 100 10 00 +8.1 27.4 +9.5 +9.5 ECU. 588 12.33
3472 +27.0 749 100 10 00 +7.0 34.3 +7.9 +11.1 ECU. 896 11.81
3639 +26.8 886 100 10 00 +4.5 42.4 +7.8 +10.3 ECU. 1106 11.24
3944 +27.0 1108 100 20 00 +1.4 53.0 +8.4 +5.0 ECU. 1000 10.78
4192 +27.0 1016 100 30 00 +3.3 50.2 +8.6 +4.2 ECU. 1243 10.27
4438 +27.0 1108 100 40 00 +3.9 52.9 +8.7 +3.0 ECU. 1237 10.12
4734 +27.0 1210 100 50 00 +6.8 53.5 +8.9 -8.8 ECU. 936 10.49
5050 +27.0 1253 100 50 00 +8.1 62.8 +9.4 +1.3 ECU. 1288 10.89
5299 +27.0 1377 100 60 00 +6.2 65.8 +10.1 -3.0 ECU. 1329 10.89
5564 +27.0 1457 100 60 00 +7.4 66.6 +10.7 -3.5 ECU. 1275 10.78
5837 +27.0 1510 100 70 00 +10.0 68.1 +11.6 -0.2 ECU. 1488 11.05
6116 +27.0 1552 100 80 00 +11.2 72.7 +13.1 +2.7 ECU. 1506 11.12
6410 +27.0 1628 100 80 00 +12.3 76.8 +14.5 +2.0 ECU. 1724 10.96
6613 +27.0 1677 100 90 00 +15.6 76.1 +15.5 -2.0 ECU. 1602 10.81
6858 +27.0 1706 100 90 00 +17.6 78.4 +16.0 -1.5 ECU. 1666 10.86
7107 +27.2 1748 100 90 00 +19.7 78.7 +16.2 +0.5 ECU. 1329 11.01
6613 +27.2 93 7 00 00 +38.6 7.1 ECU. +0.0 ECU. 72 11.28
5537 +27.0 1004 100 40 00 +18.0 41.8 +12.5 -3.9 ECU. 968 12.39
5359 +26.6 1225 100 30 00 +7.6 58.0 +10.6 +0.2 ECU. 1322 13.65
5350 +26.6 1424 100 20 00 +5.2 67.9 +11.0 +1.6 ECU. 1219 12.11
5473 +26.6 1461 100 40 00 +5.5 66.5 +10.2 -3.8 ECU. 1404 10.53
5630 +26.8 1488 100 60 00 +6.9 66.5 +10.8 -3.3 ECU. 1445 10.67
5807 +27.0 1547 100 70 00 +8.1 68.8 +11.1 -0.1 ECU. 1533 11.05
5931 +26.8 1592 100 80 00 +8.8 72.9 +11.6 +4.5 ECU. 1602 11.12
6038 +26.8 1587 100 80 00 +11.2 75.3 +12.4 +3.6 ECU. 1612 10.87
6161 +26.8 1607 100 80 00 +12.4 73.5 +13.4 +2.7 ECU. 1572 10.68
6325 +26.8 1644 100 80 00 +13.3 75.5 +14.1 +2.0 ECU. 1773 10.81
6397 +27.0 1644 100 80 00 +14.5 74.9 +14.6 +2.0 ECU. 1602 10.93
6574 +26.8 1689 100 90 00 +16.3 75.1 +15.0 -2.9 ECU. 1712 10.93
6693 +26.8 1712 100 90 00 +17.3 74.2 +15.5 -1.7 ECU. 1666 11.05
6830 +26.8 1700 100 90 00 +18.3 76.4 +15.9 -1.2 ECU. 1712 11.18
6901 +26.8 1742 100 90 00 +18.3 78.7 +16.0 -1.6 ECU. 1689 11.14
7062 +27.0 1730 100 90 00 +19.2 77.9 +16.2 -1.0 ECU. 1712 11.08
6988 +27.2 164 9 00 00 +38.6 9.3 ECU. +0.0 ECU. 156 11.05
6397 +27.0 70 8 00 00 +38.5 6.5 ECU. +0.0 ECU. 491 11.93
5144 +27.0 972 100 30 00 +14.1 47.4 +11.0 +1.2 ECU. 1136 13.95
5324 +27.0 1285 100 20 00 +10.1 61.4 +10.9 +2.0 ECU. 1288 13.39
5249 +27.0 1326 100 30 00 +7.1 65.3 +11.0 +1.4 ECU. 1329 11.18
5402 +27.0 1326 100 50 00 +8.3 62.7 +9.8 -2.1 ECU. 1388 10.46
5446 +27.0 1358 100 60 00 +6.4 61.5 +10.2 -3.9 ECU. 1428 10.81
5491 +26.8 1396 100 70 00 +5.1 66.0 +10.1 -1.6 ECU. 1329 11.23
5555 +26.8 1436 100 70 06 +3.6 67.6 +6.3 -1.3 ECU. 1302 11.33
5659 +26.8 1416 100 70 00 +3.7 65.6 +6.5 -0.9 ECU. 1428 11.28
5688 +26.8 1453 100 80 00 +3.6 72.2 +6.6 +5.7 ECU. 1582 11.27
5777 +26.8 1436 100 80 00 +3.6 69.3 +10.9 +5.2 ECU. 1552 11.12
5827 +26.8 1515 100 80 00 +3.6 73.7 +11.3 +5.0 ECU. 1506 10.87
5858 +26.8 1501 100 80 00 +4.8 73.5 +11.6 +4.8 ECU. 1506 10.74
5995 +26.8 1524 100 80 00 +6.5 72.3 +12.0 +4.5 ECU. 1582 10.78
6027 +27.0 1582 100 80 00 +6.5 73.0 +12.1 +4.0 ECU. 1524 10.81
6060 +26.8 1572 100 80 00 +6.7 74.0 +12.6 +3.6 ECU. 1543 10.78
6161 +26.8 1577 100 80 00 +7.9 74.4 +13.1 +3.1 ECU. 1582 10.80
6218 +26.8 1572 100 80 00 +9.4 77.2 +13.5 +2.5 ECU. 1700 10.83
6253 +26.8 1597 100 80 00 +8.9 77.0 +13.9 +2.0 ECU. 1533 10.78
6325 +27.0 1618 100 80 00 +8.8 77.3 +14.2 +2.0 ECU. 1700 10.71
6397 +27.0 1644 100 90 00 +11.4 75.3 +14.3 -0.9 ECU. 1700 10.71
6410 +27.0 1689 100 90 05 +10.0 77.3 +10.6 -1.8 ECU. 1524 10.76
6497 +27.0 1666 100 90 00 +9.8 75.9 +10.8 -1.3 ECU. 1592 10.86
6574 +27.0 1683 100 90 00 +11.0 75.0 +11.0 -3.1 ECU. 1700 10.96
6640 +27.0 1677 100 90 00 +11.4 76.5 +15.3 -2.4 ECU. 1623 11.02
6693 +27.0 1672 100 90 04 +8.6 76.0 +15.5 -1.7 ECU. 1677 10.99
6706 +27.2 1689 100 90 02 +7.3 77.0 +15.7 -1.5 ECU. 1724 10.96
6761 +27.0 1700 100 90 00 +8.3 79.2 +15.9 -1.9 ECU. 1689 10.89
that's a log from a 2-4 gear run. Notice the odd knock in 4th gear. Maf hz seem to be fine from switching back to the stock bov. Timing is super low due to the knock.
2901 +26.8 441 33 10 00 +29.5 19.2 +34.8 +5.0 ECU. 384 14.65
2752 +26.8 371 77 10 00 +17.6 16.1 +10.9 +5.0 ECU. 396 14.61
2822 +26.8 395 100 10 00 +16.5 17.6 +10.7 +5.0 ECU. 426 14.30
2901 +26.8 426 100 10 00 +13.6 18.9 +10.3 +5.0 ECU. 390 13.62
3000 +27.0 465 100 10 00 +11.9 21.3 +10.0 +6.0 ECU. 465 12.92
3095 +27.0 547 100 10 00 +10.3 24.0 +9.9 +7.0 ECU. 629 12.42
3177 +27.0 622 100 10 00 +7.6 28.0 +9.8 +8.5 ECU. 718 11.98
3290 +27.2 690 100 10 00 +5.2 34.2 +9.5 +9.5 ECU. 905 11.62
3443 +27.0 846 100 10 00 +4.5 38.4 +8.3 +8.0 ECU. 939 11.17
3572 +27.0 996 100 20 00 +1.7 48.3 +7.4 +4.5 ECU. 922 10.74
3691 +27.0 967 100 20 00 +4.1 39.6 +7.7 +1.5 ECU. 1020 10.74
3849 +27.0 1018 100 30 00 +5.0 41.8 +8.0 +3.2 ECU. 961 10.86
4030 +26.8 1050 100 40 00 +5.4 51.0 +8.5 +7.0 ECU. 1121 11.37
4156 +26.8 1072 100 40 00 +4.1 54.9 +8.5 +7.4 ECU. 1141 11.68
4312 +26.8 1108 100 40 00 +4.1 54.0 +8.5 +6.5 ECU. 1037 11.06
4420 +27.0 1187 100 40 00 +4.6 53.7 +8.5 +4.0 ECU. 1106 10.65
4642 +27.0 1196 100 50 00 +5.7 54.7 +8.5 -6.0 ECU. 1096 10.67
4748 +27.0 1228 100 50 00 +8.8 54.5 +8.5 -10.0 ECU. 1168 10.86
4887 +27.0 1256 100 50 00 +8.7 60.5 +9.2 -1.3 ECU. 1315 11.24
5096 +26.8 1340 100 60 00 +8.0 65.5 +9.8 +1.7 ECU. 1336 11.37
5241 +26.6 1420 100 60 00 +7.8 67.2 +10.2 -4.2 ECU. 1396 10.96
5350 +26.8 1432 100 60 00 +7.9 63.2 +10.5 -3.0 ECU. 1420 10.76
5491 +26.6 1488 100 70 00 +8.0 67.1 +10.7 -1.6 ECU. 1366 10.86
5630 +26.6 1515 100 70 00 +8.5 69.6 +11.1 -0.7 ECU. 1436 11.05
5767 +26.8 1524 100 70 00 +9.9 67.7 +11.5 -0.1 ECU. 1543 11.05
5889 +26.8 1557 100 80 00 +9.3 77.7 +12.2 +4.8 ECU. 1582 10.95
6027 +26.8 1552 100 80 00 +11.1 76.6 +13.2 +4.0 ECU. 1644 10.78
6150 +26.8 1577 100 80 00 +12.4 74.3 +13.8 +2.7 ECU. 1724 10.59
6337 +27.0 1628 100 80 00 +13.4 75.2 +14.7 +2.0 ECU. 1644 10.65
6410 +27.0 1623 100 90 00 +15.7 73.9 +15.4 -2.3 ECU. 1644 10.68
6548 +27.0 1644 100 90 03 +15.3 76.0 +15.9 -2.7 ECU. 1666 10.81
6653 +27.0 1661 100 90 00 +15.8 77.5 +16.4 -2.0 ECU. 1592 10.99
6775 +26.8 1672 100 90 00 +16.1 78.8 +16.8 -1.2 ECU. 1689 11.01
6930 +26.8 1672 100 90 00 +17.1 77.3 +16.8 -1.7 ECU. 1655 10.96
6988 +27.0 1689 100 90 00 +18.3 80.5 +16.8 -1.5 ECU. 1623 10.95
7122 +27.0 1672 100 100 00 +18.5 81.9 +16.8 +1.0 ECU. 1760 10.95
Here's a good 3rd gear pull. Slight knock at 65, this baby needs to get on a dyno. It's a very odd car. It wouldn't knock in 2nd or 3rd, but it would go nuts in 4th gear. Very odd indeed.
The car is knocking is higher gears for a few reasons.
1) If your AFR is that rich and you are still knocking, you are running to much ignition advance.
2) In the higher gears you are putting more load on the car, which is usually why we tuned in 4th gear. It allows the wideband to have more resolution because you are going through the gears alot slower. Road tuning is great to get close but Dyno's offer the ability to max out 4th gear and place usually the proper amount of load on a vehicle, without going to jail
Also what kind of gas an how much boost are you running?
.Also what kind of gas an how much boost are you running?
i doubt that timing is high. 93 shell and 19 psi tapering down to 18. I suspect the shop that installed the cam gears has tampered with the exhaust timing cam sensor.
I have to agree on Jeramine on this one. Dont take chances on knock. If you can get it to show up consistently (twice in a row) I would retard the timing just a tad to see if it goes away.
