tuning with SAFC
Old Sep 1, 2005 | 02:55 PM
li1p1aya's Avatar
tuning with SAFC
read this from Socal.net
http://www.socalevo.net/index.php?op...d=16&Itemid=33
also read this on Evom
https://www.evolutionm.net/forums/sh...d.php?t=155359
I'm a newbie w/ tuning, which one should i follow? the one from Socal looks like it isn't using a wideband O2? correct me if i'm wrong.
Old Sep 1, 2005 | 05:49 PM
o4whtevors's Avatar
no it does not show the wideband it shows the stock o2 sensor voltages. i swear by the wideband, it shows you in real time your exact afr witch is much better than going off precat o2 voltage. as i said in my post on how to use your afc, a stock o2 or narrow band isnt the best thing to tune with. how ever if you have an egt or logger you will be able to make due with it. just be carefull.
just out of curiosity what mods do you have? and also what gauges are you using?
Old Sep 1, 2005 | 10:46 PM
li1p1aya's Avatar
dont haven't any mods yet, gauges i have bought so far is boost, EGT and oil temperature. Already got a SAFC on the way and looking at buying a wideband o2 sensor, probably PLX. After that i'm gonna start modding
Old Dec 7, 2005 | 02:20 PM
ctninea's Avatar
its always good to wideband and know how your car is runnin
