Weird Boost Issues with EBCS Solenoid
Old Sep 11, 2005 | 01:37 PM
nyscooby's Avatar
Hi there, i bought the EBCS boost solenoid a few weeks ago and had it fitted by a tuner the other day.
They fitted a MAP sensor at the same time.
All to my Power FC unit on my Evo 7.
It all works but at high boost it pulses and fluctuates up and down +/- 0.3 bar
It is set to peak at 1.45 bar and goes up and down from there.
The tuners said it was OK but the solenoid is running a different hertz to the power FC and i should use the Apexi solenoid to cure the problem.
So, what can you do to help???
What is wrong with using the EBCS with the power FC unit?
Can i fix the up and down boost thing?
Please help.
Thanks
Bill.
