just bought utec used???
Old Sep 14, 2005 | 06:38 PM
04 rs's Avatar
i just bought a used utec and i have acouple questions. Is it suppsed to come with a cd or something to download the program onto my computer?? How do i download software upgrades from the website?? i wanna make sure i have the newest software. Is there anything i have to do to the utec when i download the software??? whats the toggle switch for on top??? and whats the lil red knob on the side for???
id be very greatfull for any help so thanks in advance
Old Sep 14, 2005 | 06:54 PM
EvoTech's Avatar
The red knob is for switching maps. You can download. 1.7 from Turbo XS and then upload it to the UTEC. The switch is for uploading the newest firmware. No CD. You need to download the UTEC manual and read it over and over again. It will answer all of your questions. Good luck. The UTEC is great but you need to do your homework to get the most out of it.
Old Sep 14, 2005 | 07:44 PM
04 rs's Avatar
hey thanks for the reply, well the utec came with the map switcher so i guess i just plug that in and leave the red knob at 0??? i tried to download the manual but it wont work on my computer im gonna try it on another computer tomarrow. which way is the toggle switch supposed to be when not downloading software??
Old Sep 14, 2005 | 08:39 PM
joeymia's Avatar
The manual for UTEC is a pdf file. Make sure you have Adobe Acrobat Reader installed. You can download it for free from:
http://www.adobe.com/products/acrobat/readstep2.htm
Do you have a Wideband O2 reader? You really should invest in one before doing any tuning on your car.l
Old Sep 15, 2005 | 04:57 AM
MalibuJack's Avatar
You'll need to download the Adobe PDF reader to use the manual.. once you download that you'll be fine.
The red knob is left at 0 when you use the map switch, so your on the right track.
If your holding the UTEC with the wiring harness end facing away from you, the switch should be away from you if I recall.. That should put it in RUN mode.
TurboXS really should label it, but the manual does explain everything you need so I'd recommend downloading and printing it, read through it a few times..
Old Sep 15, 2005 | 05:52 AM
04 rs's Avatar
thank you very much everyone
Old Sep 15, 2005 | 08:41 PM
04 rs's Avatar
so i just read the manual and im still a lil bit confused about something. i want to download the lastest software from turbo xs site. So in the manual it says i should have two toggle switchs and i should set the toggle switch to the flash setting when downloading new software. I dont know which way the toggle switch should be, should it be switched towards or away from the female plugs when downloading new software??
Old Sep 15, 2005 | 09:25 PM
SoR's Avatar
SoR
On the back side of UTEC there's a hole with one switch only (at least mine is that way). I think the dip switches are on the WRX only. You only have up and down and if it's mounted in the car, it's a b1tch to operate the switch
Old Sep 16, 2005 | 03:47 AM
04 rs's Avatar
yea i see that but which way is which??
Old Sep 16, 2005 | 06:17 AM
SoR's Avatar
SoR
I don't remember anymore but I think down is flash mode, up is normal mode.
If it's in the wrong position you won't be able to flash it...
Old Sep 16, 2005 | 07:08 AM
MalibuJack's Avatar
Thats true.. also if your uploading maps if its in program mode it may not save changes.. If one way is troublesome, then switch it to the other position.. There's no dip switches just a toggle switch..
Old Sep 16, 2005 | 07:14 AM
LEVIII's Avatar
will I be ok to flash the 1.7 to mine with cali 91 octane?
Old Sep 16, 2005 | 07:31 AM
MalibuJack's Avatar
Yes, but you will have to add about 10%-20% fuel across the board to compensate for the crappy gas, you should also pull 1 degree of timing from the timing map across the board until the car can be tuned..
Old Sep 16, 2005 | 07:35 AM
LEVIII's Avatar
Im going to be doing the tuning myself, Im just still doing alot of research and learning and finding where I should start from.
Cali sucks for the junk gas here.
Vivid Racing
13
May 27, 2007 02:45 PM
LEVIII
Sep 15, 2004 08:46 AM
batty
Jul 25, 2004 04:03 PM
PDXEvo
65
May 23, 2004 10:10 PM
Illrunya
Mar 18, 2004 09:13 PM
