xs tuner
xs tuner
For those who using the xs tuner, a. Do you like it better than other wb out in the market? I mean is it just a wb and all the data log info is in the utec right? and b. wth do you put the thing in your car?
I have a Tuner Pro also, Feature wise, the pro has the ability to use additional inputs, I only wish the firmware would give you the option to append this additional input data (EGT, Etc) to the UTEC logs..
The big reason I like it is because it works with the UTEC, Originally I had pre-ordered the AEM UEGO gage... When the UTEC was announced officially and the tuner pro was released, I got both around the same time.
I mounted mine of all places, in the glovebox.. I used the Tuner Pro's wideband output on the side, to hook up a PLX Devices Wideband Gauge that looks similar to my other gauges on the dash. The main advantage is all my hardware is basically hidden out of view.
