Misfire
Old Oct 9, 2005 | 07:43 AM
Dingo7's Avatar
Misfire
i am haveing a problem with a misfire in my utec map. i bought the car used and had this map, i dont know who tuned it. can ne 1 tell me were the misfire would be in the ignition map? once this question is answered i have about a thousand more question ne help would be great guys
Old Oct 9, 2005 | 09:24 AM
dryad001's Avatar
Post up a log first. Also check your plugs this could be the cause of it. I use the NGK BPR7ES.
Old Oct 9, 2005 | 11:48 AM
Dingo7's Avatar
wats a log im new and i know its not the plugs
Old Oct 9, 2005 | 11:55 AM
Dingo7's Avatar
dryadd001 the car misfires on the utec map but when put on the stock (0) map it is mine but runs like garbage above 5000 rpms to red none of the plugs have ark
Old Oct 9, 2005 | 11:58 AM
dryad001's Avatar
Here is what a log should look like, now it all dependis on what program you are using, i.e. UCC, hyperterminal, MPS. This is a log using the MPS software.
3109, +0.4, 558,100, 10, 00, 13.5, 18.1, +6.5,-11.2,ECU. , 683
3300, +3.0, 641,100, 10, 00, 12.5, 22.8, +5.8,-12.6,ECU. , 524
3465, +5.9, 806,100, 10, 00, 12.4, 27.5, +5.4,-14.6,ECU. , 827
3667, +8.9, 996,100, 10, 00, 12.6, 39.0, +5.3,-15.0,ECU. ,1121
3940,+12.8,1243,100, 20, 00, 11.6, 47.8, +5.9,-18.0,ECU. , 988
4224,+17.2,1308,100, 30, 00, 11.3, 46.2, +6.6,-23.7,ECU. , 909
4516,+21.1,1355,100, 40, 00, 12.0, 48.7, +7.5,-23.7,ECU. ,1063
4796,+24.1,1457,100, 50, 00, 12.3, 51.4, +7.6,-23.2,ECU. , 988
5120,+25.8,1510,100, 60, 00, 12.0, 55.0, +7.8,-23.4,ECU. ,1269
5455,+26.1,1628,100, 60, 00, 11.9, 58.5, +9.3,-24.7,ECU. ,1116
5737,+26.1,1666,100, 70, 00, 11.7, 63.0,+11.0,-27.1,ECU. ,1351
6038,+25.8,1754,100, 70, 00, 11.7, 65.2,+14.2,-26.9,ECU. ,1243
6361,+25.4,1831,100, 80, 00, 11.6, 66.2,+16.5,-28.9,ECU. ,1275
6640,+24.7,1872,100, 80, 00, 12.0, 65.8,+19.3,-30.0,ECU. ,1366
6915,+24.1,1886,100, 80, 01, 12.0, 67.4,+21.5,-29.6,ECU. ,1358
7153,+23.7,1915,100, 90, 00, 10.9, 75.8,+22.2,-29.0,ECU. ,1515
7407,+23.0,1968,100, 90, 00, 10.8, 74.3,+22.3,-28.8,ECU. ,1344
This is an old log but it gives you an idea what you should be seeing.
Old Oct 9, 2005 | 12:02 PM
Dingo7's Avatar
i cant even post a log right now b/c i dont have a labtop and i did not get the serial cable or 9v cable to bring it to my comp
Old Oct 9, 2005 | 12:10 PM
dryad001's Avatar
Yup you need a laptop to log, makes life a lot easier. I would keep it on Map 0 till you can either buy or borrow a laptop. In order to use the UTEC out of the car it must have power to it, hence the 9v source.
Old Oct 9, 2005 | 12:13 PM
Dingo7's Avatar
thats the problem the stock ecu runs fine but it does some wierd things above 5000 rpms and its is even worse in 2nd and 3rd th car feels like it is bogging down on and off quickly.
Old Oct 9, 2005 | 12:15 PM
Dingo7's Avatar
only go fas6t goodies are fmic fuel rail and gutted cat
Old Oct 9, 2005 | 02:26 PM
BJai02's Avatar
fuel rail is the culprit... you will need to get your car tuned for it. Map '0' will be simply running the stock ECU without any changes form the UTEC. I don't think your car will stock ECU along with the aftermarket fuel rail.
