question about rpm converter
Old Jan 1, 2006 | 05:14 PM
tehforbes's Avatar
Alrite, finally got my LM-1 and rpm converter shipped to me.
I went ahead and ordered that little inductive clamp because I don not want to splice any wires. Just clamp it onto spark plug wire and hooke it up to converter....am i right ?
I was also reading the manual for it and it said in most cases the grnd connection of the rpm converter is required only if the other Aux Inputs(2-5) are used.
Is this all as easy as I am seeing it ?
Old Jan 1, 2006 | 07:26 PM
Widebandphillip's Avatar
I have the same setup. Just clamp the inductive clamp on the number 1 spark plug wire and connect the other end to the slot in the rpm converter. I don't think you need to use the ground wire since the lm-1 unit is already grounded through the cigarette lighter.
Old Jan 2, 2006 | 12:08 PM
tehforbes's Avatar
alright thank you man.
i appreciate the info.
roevo
Aug 5, 2014 05:58 PM
kaj
Oct 2, 2009 04:33 PM
xLaNcErEvOx
Jan 31, 2007 09:55 PM
xLaNcErEvOx
Oct 19, 2006 12:05 AM
HAALN
Jul 23, 2004 08:11 AM
