V4.5
Old Feb 24, 2006 | 09:17 AM
dryad001's Avatar
V4.5
Looks like it will work nicely, I haven't uploaded to the maft yet since work won't let me have a day off. But to try and get a head start so the transition is smooth what should all of the new constants be?
Timing monitor, base
timing monitor correction
fe smoothing
tb size (scott said 7 was a good starting point)
tps filter
map filter
Im assuming I leave all of these at 0 for now except the tb size, correct?
Old Feb 24, 2006 | 09:24 AM
PVD04's Avatar
fe smoothing
tps filter
map filter
Not sure about timing monitor stuff, as I haven't played with it much, but you want to set TPS filter to ~70 and MAP filter to ~140. Those settings have worked well for me. FE smoothing is just a smoothing setting for your flow error. If you aren't logging/monitoring flow error it won't affect anything you're using.
TPS filter and MAP filter are there to help smooth the TPS and MAP signals before enrichment is applied. Higher settings result in less filtering, lower settings have more filtering which also can create slightly more lag in the TPS and MAP response.
Also take note of the MAP and Boost enrichment settings. MAP enrichment is similar to the previous version, but it is only effective up to 100 kpa at which point Boost enrichment takes over.
*edit* - Boost enrichment is in version 4.51. I'm not sure if 4.51 has been released yet. If not, disregard the last section of my post.
-Paul
Old Feb 25, 2006 | 08:16 AM
dryad001's Avatar
What ads file is everyone using? The latest one I have is Tpro4400.ads When I try and load everything there is a mismatch of ads and xdf files. Now not being the one to talk to about computers I am pretty lost. Will this be alright?
Old Feb 25, 2006 | 09:26 PM
PVD04's Avatar
If you PM me your email address I can email Tpro4500.ads to you.
-Paul
Old Feb 26, 2006 | 08:32 PM
TurboBob's Avatar
the ads mismatch warning is no big deal.
You need matched XDF and ADS files to enable the ALDL "Data Tracing".
Bob
