I am in the bay area should that effect purchase
saleen281 - Finding the right tuner is very important because it helps not only to create a geographically convenient help source, but it allows you maintain your car at peak conditions regularly. In comparison to a mail-in flash, your car will be custom dynotuned to your cars specifics. Being in close proximity will ultimately yield the most readily available support.
have you check out our power packages?
Our Gruppe-S Flash, after much dyno-testing adjusts boost maps, ignition maps, fuel trims, and various other parameters to maximize the effects of installation our power-package parts. Built in are ECU safety features such as knock control and fuel trim, creating a safe and reliable tune.
click ->
Were located in Hayward, Ca (Bay Area) 880 off of Industrial
thanks,
Daniel
click ->
thanks,
Daniel
