Setting ECU+ TO stock
Old Jun 26, 2006 | 11:34 AM
AutobonEvo's Avatar
I have a garbage tune on my ecu + right now. I want to set the ecu+ back to zero and start from scratch how would i do that?
Old Jun 26, 2006 | 11:38 AM
Faust's Avatar
Mis-read the OP's post...I'm an idiot! Sorry!
Old Jun 26, 2006 | 11:42 AM
kimletrim's Avatar
Registered User
Originally Posted by Faust
You contact the company that flashed your ECU and tell them to put it back to stock. Otherwise if you did it yourself you SHOULD have saved a copy of your Original Flash and then you just flash over your "Garbage Tune".
you have no idea what the OP is asking.
The ECU+ is a piggyback ECU, it does not flash the stock ECU.
Wit the ECU+, just zero everything out (fuel map, timing map) and get rid of any injector scaling. This should take care it. Or you can just unplug the ECU+ module since it is plug and play.
Old Jun 26, 2006 | 11:48 AM
AutobonEvo's Avatar
^ thank you
