Formatting Issues During Logging
Is it just me, or do others have this issue as well? It occurs both on the "on-screen" 25 second replay mode, and also if you save the log to disc. About every 20 lines or so, one line will be just jibberish, and throw off the next lines formatting as well. Trying to convert to exel format is difficult at best, with truncations being carried over into the next cell, etc.
Another thing.... when editing maps, when they first pop up on screen, some cells in the 2D matrix will be filled with garbage or even blank, until you roll over them with the cursor to change them, then they display the correct value.
Is it my setup or is this common? I'm running the 1.7 version software.
