idle problem
Old Sep 23, 2006 | 10:08 AM
Eshark's Avatar
Unhappy idle problem
I'm having idle trouble and was looking for a little direction. A little back ground first. I was drive to work on Wednesday morning and heard a noise from the engine bay and the car just died. Started it back up, and the idle surged from 2K to 3K rpm every second. When I got the car back home it seemed the exhaust manifold gasket was leaking air. Once I replaced the gasket the surging problem was fixed, but now the car idles fine with the A/C on (MAS around 50 and timing around +16). When you turn the A/C off the MAS reading jumps to 80-90, and the timing is advanced to the 30's. Any clue as to what the problem might be?
On Tuesday I changed the oil, spark plugs (gapped .022 to.024), and replace the hose from my boost controller to wastegate (it wasn't looking to good). I rechecked everything, and there are no leaks, as I also did a boost leak test on Tuesday. On thing I noticed when I finished the leak test; I noticed a little condensation on the turbo inlet, not sure if this could screw up one of the sensors, just something to think about when trying to diagnosis the problem.
Mods are:
HKS Turbo Timer
LPI 3" TBE with cat-delete
Hallman Pro Boost Controller
dynoflash -base flash to clear rev limiter etc.
ECU+
O2 housing
Fighters Garage Lower IC pipe
Fighters Garage Intake with UICP
Walbro 255 Fuel Pump
ARP Head Studs
GSC Camshafts 272i/264e
Snow Performance Alky Kit with safe injection
Spark plugs - NGK BPR8ES
All of which has been installed for at least 3 months with no problem.
If anyone can think of something let me know.
Thanks,
-Eddie
Old Sep 23, 2006 | 06:00 PM
Eshark's Avatar
anyone?
Old Sep 26, 2006 | 08:22 PM
Eshark's Avatar
Guys I still need help. I still have a really bad idle, as mentioned above. I've checked all the vac lines, sensors, and all IC pipes. The advanced timing is confusing. Is this an ECU problem? Is there anything else besides the ECU that can advanced timing like this. I’ve unplugged my ECU+, and the problem continuous. I’m thinking the ECU fried. Any help would be greatly appreciated.
-Eddie
Old Sep 26, 2006 | 08:25 PM
Eshark's Avatar
A/F's are normal, and the check engine light isn't coming on, and today the ACD lights came on. I'm lost as to whats going on.
Old Sep 26, 2006 | 08:40 PM
cfdfireman1's Avatar
Reset.
Try resetting the computer. Disconnect the battery for a few minutes reconnect, start the engine and let it idle for 10 minutes after warmed up.
Old Sep 26, 2006 | 08:41 PM
Eshark's Avatar
yeah...sorry.... I already tried that a few times without luck.
Old Sep 30, 2006 | 10:23 AM
testa corse's Avatar
No worries
Mods are:
HKS Turbo Timer
ECU+
O2 housing
ARP Head Studs
Thanks,
-Eddie
Hi Eddie,
I am Fotis from Greece and my job is to tune some evo's here in Greece.
Your idle problem could be fixed by starting to clean your throtle body very very well and if your idle still is not stable there is a little by-pass screw on your throtle body which you can adjust the idle. If your problems insists, replace the steper motor.
I hope i could help a little bit from the far away Greece.
Let me know.
Old Sep 30, 2006 | 10:27 AM
AJsGenerX's Avatar
^^That screw is known as the base idle set screw^^....it is located on your throttle body. I dont believe that is the problem though. It doesn't hurt to check though.
Old Sep 30, 2006 | 10:30 AM
AJsGenerX's Avatar
http://images.google.com/imgres?imgu...lr%3D%26sa%3DG
Thats for DSMs....but you're looking for something similar on your Evo VIII Throttle Body.
Old Sep 30, 2006 | 08:58 PM
Eshark's Avatar
yeah the screw doesn't help. Plus it doesn't explain the advanced timing. I'll check the stepper motor. The TB has been cleaned and it didn't fix the problem.
Thanks,
-Eddie
Old Oct 1, 2006 | 07:25 PM
Eshark's Avatar
yeah its the stepper motor, or IACV ( idle air control valve. The meth fried it. Does anyone know where i can get one besides the dealership?
-Eddie
blade3609
44
Nov 6, 2011 12:44 PM
EvoXHoosier
12
Oct 7, 2010 03:06 PM
NOMIEZVR4
14
May 18, 2010 09:54 AM
dxbtune
Jul 6, 2009 04:43 PM
CalebL
22
May 15, 2008 04:50 PM
