C16 on a car not tuned for it?
Old Nov 17, 2006 | 12:45 AM
ant_turbo's Avatar
What will C16 do to a EVO_IX that is not tuned for it but!! Only has a pump gas tune?? THANKS,,,
Old Nov 17, 2006 | 01:06 AM
03redtype-s's Avatar
would like to know this also
Old Nov 17, 2006 | 01:41 AM
andifidie's Avatar
make a ****load of power if you turn up the boost
Old Nov 26, 2006 | 05:14 PM
thaigleshmk's Avatar
nothing is happening if you are not gonna change any settings but putting the race gas in .... it's all just gonna stay the same except u just waste ur money... for gas..(expensive gas)
Old Nov 30, 2006 | 04:49 AM
recompile's Avatar
From http://en.wikipedia.org/wiki/Octane_rating:
Using a fuel with a higher octane lets an engine run at a higher compression without having problems with knock. The power output of an engine depends on the energy content of its fuel, and this bears no simple relationship to the octane rating. A common myth amongst petrol consumers is that adding a higher octane fuel to a vehicle's engine will increase its performance and/or lessen its fuel consumption.
It may, however, allow you to turn up the boost safely, without worrying about knocking.
Old Nov 30, 2006 | 05:07 AM
Soon2BEVO's Avatar
It depends how much you put in. Its actually possible to LOSE power from running race gas if you are not tuned for it., unless your current tune has a lot of knock in it. The best thing you can do it i throw on 2 gallons or so on top of half a tank and crank the boost up 2 more psi.
Old Dec 2, 2006 | 12:40 AM
Jax419's Avatar
^^ I dont think its possible to loose power if you run race gas and then crank up the boost a bit!
Old Dec 2, 2006 | 04:45 AM
Soon2BEVO's Avatar
Depends how much race gas you use. Best thing to do is like I said, throw in about 20% and crank boost up 2-3psi max.
Old Dec 2, 2006 | 04:56 AM
Evoryder's Avatar
just use 100-103oct and go have fun.... C16 is leaded ...and unless u want to waste the life of your o2 sensors by "seeing what it would do" ...i wouldnt ...that's an aggressive gas....works wonders when you're tuned aggressively...more timing...lower egts ...etc
Old Dec 2, 2006 | 04:07 PM
Jackson Machine's Avatar
Yes it is. Higher octane fuels have a slower burn rate and will not make power unless your motor can optimize it, regardless of the tune. More often that not it will make less power with race gas.It will be more resistant to detonation but if you've got your car setup right and tuned properly that shouldn't be an issue anyway.
