change setting to use 3.5 bar map?
Old Jun 22, 2007 | 02:51 PM
joosdawg's Avatar
Do i have to change any settings to run a AEM 3.5bar map on the maftpro or will it just recognize it as is if installed per instructions?
Old Jun 22, 2007 | 04:07 PM
PVD04's Avatar
One of the settings lets you choose your MAP source. It's called the "Manifold Pressure Source"
-Paul
Old Jun 22, 2007 | 04:08 PM
joosdawg's Avatar
thats set at 0.00 right now, what should i set it at?
Old Jun 22, 2007 | 04:13 PM
joosdawg's Avatar
nevermind just found it in the manual to set map source to 1 thanks again bro
