utec not reading correct boost
Old Jun 26, 2007 | 05:42 AM
BoostN's Avatar
I have a utec and everything seems to be working fine but it will not read above 9psi in the logs. I'm running a AVCR and not the utec ABC. I have it set up the same way on my subie and it reads up to 26.3psi on the logs.
Any advice?
Old Jun 27, 2007 | 03:42 PM
MalibuJack's Avatar
Two things, do you have the gm sensor hooked up, and also, is it hooked up to a vacuum source that isn't being restricted in some way?
Old Jun 27, 2007 | 03:56 PM
BoostN's Avatar
I'm using the stock sensor and no, nothing apears to be restricted.
thanks
Old Jun 28, 2007 | 04:14 AM
MalibuJack's Avatar
no external GM map sensor, no boost reading... UTEC requires an external sensor to read boost.
Old Jun 28, 2007 | 07:08 AM
Mad_SB's Avatar
yup, the does not have multibar map sensor, at least not the us evo. You have to use the dtec map sensor or wire up a gm 3bar.
Old Jun 28, 2007 | 07:17 AM
BoostN's Avatar
gotcha, funny thing is I've tuned 4 maps on a dyno and never noticed till lately logging on the road. I was using the AVCR settings and the boost graph from the dyno to tune originaly. Guess you dont see what your not looking for. LOL
On the subies it just reads off the stock sensor.
thnks again.
