Max wastegate duty
Old Jun 29, 2007 | 11:17 AM
GOTBOOST1023's Avatar
Max wastegate duty
My max wastegate duty is at 127.5. Would it be safe to make that higher. I recently put a front mount on and now sometimes I get the overboost code. I just raised my boost cut and delay timer but Im wondering if I should change anything else.
Old Jun 29, 2007 | 11:22 AM
TouringBubble's Avatar
The boost cut is caused by the boost limit and boost limit delay timer. Increase the boost limit value to raise the cut point and increase the timer to allow it to pass the limit a little longer before cut.
Old Jul 2, 2007 | 01:22 AM
EvoInvidia's Avatar
I didn't know there was a boost cut? Only fuel cut..same difference?
Old Jul 11, 2007 | 11:27 AM
Yes same thing.
