Help..Stalling with stock BOV
I just got MBC, Cams and Tune.
My car's idle goes down whenever I push in the clutch when slowing down.
If I have the a/c on, the symptom increases and stalls the car.
I even switched to stock BOV hoping that would solve the problem, but nothing.
I checked all the hoses but they seemed okay.
Do I have a leak somewhere?
Please help... I tried some searching but nobody had the same symptom as I have.
I don't know if this helps.. but i had the same problem when I was bone-stock..
When I got tuned... there is an area in EcuFlash where you can up the idle speed when the AC is on... I had my tuner play with those to try it out. It seemed to have helped.
My problem was intermittent... and seemed to get better after that...
I tried raising the idle with ecuflash. I raised it up to 1200 with a/c on and 1000 without. Although it made the car stall less, it didn't make the problem go away. Car still stalls on a hot condition with a/c max.
The problem is... It still happens when the a/c is NOT on. Just not as bad to stall the car. And i tried raising it to 1200(idle with a/c) which is very abnormal and it still stalled. (Although it helped)
I don't know if I should raise the idle even more.
I would not adjust the idle screw unless you know exactly what you are doing. Cams lower your vacuum at idle which makes your idle very lopey. You need to get a tune and it will idle very close to stock with cams. I have 272s and it idles fairly well. It still stumbles when ever you come to a stop and push in the clutch and hit the brakes.
Yeah I got a tune after the cam install and it idles VERY well.
But the car still shouldn't stall whenever i push in the clutch and brake to slow down.
It doesn't even have to be a complete stop.
I almost got in an accident while slowing down for a corner. The car stalled while I was making the turn. With power steering gone, I almost ran straight into another car.
