turbo mirage
turbo mirage
I have turbocharged my mirage and put in emanage blue with injector and ignition harness. I have downloaded 1.48/1.25
Here is my problem. I cannot get online? So I cannot export the data.
Someone please help me.
There is more than 1 com port,
Connect computer then with ignition in on position select one of the other com ports
Offline will change to online after the correct selection.
My computer communicates on com 2
Right click my computer. Go to manage-->device manager-->com ports double click and then look and see what com port it says it is. Then select the proper com in the emange.
Mitch
Mitch
I'll check it tomorow after work.
I just did that without cable connected to emanage. I see few usb listed, but they are not numbered. How should I know which one is which?
Again thanks.
Again thanks.
