Maft gen 2 Question
Old Nov 29, 2007 | 11:23 AM
SilentEvo8's Avatar
Maft gen 2 Question
on all my logs I have a lean spot during spool up and wanted some ideas on what I should use to try and correct it or richen it up.
its where the red circle is. I have the maft gen 2 and I do have evoscan with the tactrix cable and ecuflash..
This graph shows a more severe lean spot than most of my logs. If this is normal just let me know.
Oh my car has a blow thru set up with a 3 inch gm maf sensor. Dejon uicp and intake pipe. Rmr licp Turbo xs ic hks 272 cams Hks bov fuel pump Turbo xs mbc and 3 inch downpipe and full exhaust with test pipe. and a sun auto hyper force system head studs too.
Also I was wondering if "tip in" meant the time or area before spool up or full boost?
Thanks
Last edited by SilentEvo8; Nov 29, 2007 at 11:31 AM. Reason: list of items on car so ppl won't ask later
Old Nov 29, 2007 | 11:34 AM
SilentEvo8's Avatar
The car is ran on 91 oct and 23 spike to 21-22 psi. not sure how accurate my boost gauge is. auto meter carbon fiber one.
Old Dec 11, 2007 | 04:14 PM
steadly2004's Avatar
you should figure out what RPM/LOAD you're at in that particular spot, and add fuel if its leaning out
Old Dec 16, 2007 | 12:02 AM
BCOZEVO's Avatar
Well I have the GEN 2 so let me give it a try.
Do you have auto AF tracking on?
Is your map stock or have you flashed at all?
Can you post the excel version of your log?
ridenrunwv
Oct 5, 2015 11:39 AM
Ph3n1x
57
May 21, 2008 09:03 AM
joosdawg
For Sale - Cars For Sale
21
Apr 20, 2008 02:43 PM
EvoTech
Sep 15, 2007 05:14 AM
Evoisdream
23
Apr 13, 2005 12:14 PM
