Zeitronix EGT broken??
Old Feb 2, 2008 | 02:15 PM
DS-03evo's Avatar
All of the sudden it only reads 200c , any one have this happen?
Old Feb 2, 2008 | 06:33 PM
Zeitronix's Avatar
Check the EGT connections, if all good your EGT probe burned out.
Old Feb 2, 2008 | 10:37 PM
DS-03evo's Avatar
How long should it last? I have only had it on for 5 months.
Where can I get a new one at?
Old Feb 3, 2008 | 01:37 AM
ChuckP's Avatar
Im guessing.. Zeitronix
Old Feb 3, 2008 | 02:05 AM
Fookster's Avatar
I would give Zeitronix a call. They stand behind their products and would be very helpful.
Old Feb 3, 2008 | 02:21 AM
ChuckP's Avatar
http://www.zeitronix.com/order/order.htm#EGT
Or just pm TTP . Probably cheaper.
Old Feb 3, 2008 | 02:02 PM
DS-03evo's Avatar
It just started working again...I duno
Old Feb 3, 2008 | 03:32 PM
ChuckP's Avatar
Then you need to check the connections.
Old Feb 3, 2008 | 03:34 PM
TTP Engineering's Avatar
The probes are low mass, high response units. The fastest K thermocouples in the market. The fast reacting probes in turn have to be thin. I would plan on replacing it every 6-12 months, YMMV. Depending on how you use the car and where it is tapped.
Old Feb 3, 2008 | 09:38 PM
DS-03evo's Avatar
Good info, thanks TTP!
