Defi EGT probe slow[er]
I have Defi guages and the Defi EGT probe which is notoriously slow, is now really slow; This is after about 20k miles of use.
What is the best probe to replace the original probe with and what are the correct part numbers needed?
Thanks in advance
Thanks in advance
the orignal prob is the best they cost about $175.00. But I have one with a little less than 1000 miles on it well its a defi gauge and defi probe for 150.00 plus paypal fees let me know
Almost all EGT gauges use K type thermocouple. The difference is in the probe construction, mass etc. Some are better some then others. This is why we give you Zt-2 style 2 pin EGT connector so you can retrofit your own EGT probe. You do not have to buy one from us. Wonder if it works the other way arround?
Most EGT gauges use K type thermocouple probe. All probes have different connectors so you need to splice wires if you are using X manufacture probe with Y manufacture gauge. Of course Zeitronix probes plug right into Zt-2s. We also give you a 2 pin EGT connector to retrofit your probe when connecting to the Zt-2.
Keep in mind EGT probes are polarized.
