what injector size???
Old Aug 29, 2008 | 03:51 PM
vroomevo's Avatar
so, running 1.9 bar~27psi with meth/water, just got green turbo. now my injector duty cycle is upto 93-4%. with evo9 turbo, duty cycle was around 85%.
so, what size injector do i need to get?
any input will be very appreciated.
Old Sep 1, 2008 | 08:38 PM
mrfred's Avatar
If the IDC is at 95% with your current setup, then no need to upgrade. It seems that the duty cycle calculated by the ECU where the injectors go static is about 115%, so you have about a 20% safety margin.
