Hallman MBC, NOOB needs help
Old Sep 12, 2008 | 10:21 AM
S6devil's Avatar
i have a Hallman MBC. car was tuned on a dyno like a year ago at 23psi. if i suddenly feel the urge to "turn it up a notch", meaning raise the boost myself, at home... what's the safest and/or the most I can do, without getting a new tune, and without switching to a higher octane gas (i only use 93).
meaning, can i just raise the MBC to like 25-26 psi, if im going to a track for the day, and then turn it back down to my usual 23psi, when i come home ??
Old Sep 12, 2008 | 03:22 PM
Jay644's Avatar
I read that 24psi is the highest you should set it too any more and you'd be pushin your luck.
Old Sep 12, 2008 | 03:25 PM
markymark1082's Avatar
It depends on how your car was tuned. If it was tuned conservative then you could bump it up a little. That is something you should ask your tuner about.
Old Sep 12, 2008 | 03:27 PM
beemerfreak's Avatar
No. U will be risking ur motor by doing this.
Keep it at whatever boost u were tuned for.
Unless u run race gas than u can turn it up a little but ur better off getting retuned for the race gas because u will see a lot more power.
Old Sep 12, 2008 | 03:33 PM
magyar86's Avatar
odds are you could turn it up 2psi and be ok but if you start getting some knock you could actully end up will less power due to the ecu pulling timing. the only way to tell is to turn it up and log and see if your getting any knock. but if your going to the track i would maybe just put a few gallons of race gas in your tank and turn your boost up 2-3 psi at most and you should be fine.
plokivos
84
Jun 7, 2017 11:25 AM
6466Animal
Dec 15, 2015 11:32 AM
miniend
20
Oct 14, 2009 08:19 PM
Inprogress
South Region
Mar 22, 2009 02:41 AM
gsrmin
Feb 18, 2006 11:08 AM
