Motec M800 maps!!
Old Sep 21, 2008 | 01:24 AM
kemoly's Avatar
Motec M800 maps!!
hey guys i need some maps for the Motec m800 plag and play for the evo vII!!
thanks
Old Sep 21, 2008 | 07:38 AM
EvoJoeIX's Avatar
Motec is not a plug and play ECU
you need to have someone that knows the software and knows what they are doing to set it up and tune on it.
Motec does not offer any base maps on thier ecu's, it needs to be set-up from scratch
goodluck
Old Sep 21, 2008 | 08:49 AM
gsrboi80's Avatar
^ Motec actually does make a plug and play ECU for the EVO
It can be found here http://www.motec.com.au/pluginecus/pluginoverview/
As for base maps and such check out some Motec forums would be the best
Old Sep 21, 2008 | 09:55 AM
EvoJoeIX's Avatar
i meant plug and play in the sense of you cant just plug it, load a base map and go... sorry, my fault i should've of explained in earlier post
motec maps need to be bult from ground up, theres no base map you can start with when you tune, thats what im talking about
Old Sep 21, 2008 | 11:12 AM
gsrboi80's Avatar
No worries man. I know all of Motec ECU's used to have to be hard wired. Then they came out with the ECU that plugs directly to the factory harness.
Old Sep 21, 2008 | 12:44 PM
kemoly's Avatar
Bless the ignorant lol!!!!
Off course there is a plug and play for the evo is just that not to many people know about it , down here that ecu is use for rally and it comes with a basic mode for start the car and do some aplications ......
anyway thanks for the website gsrboi80 !!!!!
you say that you operate a motec from scracht ???? what motec did you operate???
Old Sep 21, 2008 | 01:08 PM
alex4nder's Avatar
This might sound harsh, but it's for your own good: if you have to ask for a base map, you shouldn't be the one tuning the ECU. Someone familiar with MoTeCs should be able to get the car up and idling in less than 15 minutes.
Old Sep 21, 2008 | 02:35 PM
kemoly's Avatar
i dont need a base map , i need an advance map to compare with the one i have !!!
thanks
Old Sep 21, 2008 | 07:18 PM
EvoJoeIX's Avatar
ignorance has nothing to do with what i posted....
i simply didnt explainit enough for what i was trying to say
again... my bad
Old Nov 11, 2008 | 11:05 PM
kemoly's Avatar
Also available amongst MoTeC’s wide range of engine management options are the discreet M800 Plug & Play systems.
These ECUs are designed as plug in boards to replace the OEM computers in a number of high performance late model
vehicles. These units provide the flexibility and performance of a MoTeC M800 ECU without the necessity of rewiring the
car or building adaptor looms.
M800 Plug & Play ECUs are built with the same options as a standard M800, though there are some limitations due to
factory plug designs. To assist with the tuning of your vehicle they can also be supplied with a start up engine map.
Currently available are:
13004A M800 OEM ECU for WRX/STi V5/6
13007A M800 OEM ECU for EVO8
13008A M800 OEM ECU for WRX/STi V78 + 2006 2lt model only (some models req. Cam Control upgrade (28116))
13012A M800 OEM ECU for WRX/STI V9/10
13009A M800 OEM ECU for EVO 4 – 8
13010A M800 OEM ECU for EVO 9 (some models require Cam Control upgrade (28116))
Old Nov 20, 2008 | 11:12 PM
projectevo9's Avatar
They must be really expensive. I went to Peru two years ago and I didn't see any evos...many STIs.
Old Mar 1, 2009 | 12:35 PM
kemoly's Avatar
true ... not many evos out here .... !!!!!
did you like Peru???
Old Jun 3, 2009 | 09:27 PM
saifsaif's Avatar
my hight octane map
hi there, check this map , for high octane , modes on my evo : HKS 3037 turbo , stock injectors , HKS cames
File Type: zip
Old Jun 3, 2009 | 09:48 PM
saifsaif's Avatar
kemoly, here is a new map file, ver .35 , this is for stock injectors , mid size turbo , if u can tell me which turbo u have i will help u ,,,
but i f u can just lower all the ignition value 20% in the ignition table , then u will be OK ,,,
Old Jun 5, 2009 | 04:56 AM
saifsaif's Avatar
good one
this one,, this is for 1000cc injectors , HKS 3037 turbo
File Type: zip
