Mut Monitor V1.9 Release 31/1/2009
Version 1.9 of Mut Monitor.
Had a break from soldering today and did a bit on the application.
This application uses the Mitsubishi MUT Protocol for monitoring data from the Vehicles ECU.
It can be used with OBD-II serial cables as well as FTDI based cables via Direct calls or Virtual Com Ports. At this time it seems to be the only application that will Log with the Tactrix OpenPort V2.0 Cable on Mitsubishi Vehicles.
***Note***
The OP2.0 cable seems to of stopped working since people have upgraded the Firmware to Version 1.05+
Please read this thread for more info on this.
http://www.myrollingroad.com/showthread.php?t=103
Main Changes for Version 1.9 are:
Tested exhaustedly with
Serial OBD-II Cable
VAG - COM clone FTDI Cable
Tactrix OpenPort 2.0 Cable ( See note above)
CLaNZeR USB-PIC-OBD Cable
CLaNZeR U-OBD Cable
Can be downloaded usual place at http://www.myrollingroad.com/showthread.php?t=110
Cheers
Sean.
***Note***
- Higher Baud Rate added for people that have Flashed their ECU's to support it.
- Descriptions,Request ID's and Calculations no longer hard coded and can be Edited and swapped around.
This also means you can Remove Redundant Request ID's that you do not use by editing and blanking them out and also adding Custom or New Request ID's as they are found.
All this information now gets stored in one configuration file called MutMonitor19.cfg, so you can pass custom Config files to other Mut Monitor Users instead of them having to re-type or manually add the Request ID's themselves.
- Sort Routine added, so now you can list the important stuff where you want it.
This makes Mut-Monitor nearly fully User configurable.
Serial OBD-II Cable
CLaNZeR U-OBD Cable
Cheers
Sean.
Evo Pete MTL
Lancer Engine Management / Tuning Forums
Nov 29, 2012 06:08 AM
19, httpwwwmyollingroadcom, ii, moniter, monitor, monitoring, mut, mutmonitor, op20, protocol, tactrix, usbpicobd, v15, v19, vagcom
