Cobb AP & Boost Problems
Old Nov 19, 2009 | 01:22 AM
AJR-Coco's Avatar
I just bought a unmarried AP, just wondering i installed the stage 1 94 octane map and everything is running fine. The main problem with the boost, i am using HKS EVC 6 the target boost is set up @ 17.5 psi but the stage 1 94 map its suppose to go all the way up to 20.5 psi tapering down to 17.5 psi. I want to know how i can adjust this
And next week i am adding a upgraded turbo Tomei, is it recommended i just get my car Pro Tuned by a COBB Distributor Pro tuning shop?
Old Dec 2, 2009 | 05:08 PM
darthvader's Avatar
It is best to reconnect stock boost control system you will have more consistent performance , when you upgrade to tomei turbo you will definitely need protune
Old Dec 9, 2009 | 04:49 PM
COBB Tuning's Avatar
Since you have disconnected the ECU from boost control, you will have to set up your boost targets with the boost controller. This is a perfectly reasonable method of controlling boost, but you will have to tune for it. You will need a ProTune for the larger turbo no question, we do not have any calibrations that are appropriate for the Tomei turbo.
Travis
COBB Tuning
