Is this considered knock?
Old Jun 17, 2010 | 10:12 PM
RussK3's Avatar
I recently got my car tuned. running 24 psi. Sometimes when i get on it the car feels like it cuts out for a split second. maybe leak a from stock bov? boost holds. only happens once in a while. is this knock?
Old Jul 13, 2010 | 10:31 PM
vint21's Avatar
Best way to answer that is to get a tactrix cable, download Evoscan, and log some data. The knocksum parameter will tell you whats up.
Are you feeling this issue soon after the boost spikes? Knocking tends to happen at high load and low rpm because the slower piston speed allows more time for predetonation to occur.
Old Jul 15, 2010 | 07:49 AM
myev0sneezes's Avatar
You probably have a leak. Are you running a mbc? Make sure all your vac lines in are in securely. Run some test.
Old Jul 17, 2010 | 04:29 AM
tro0xazn's Avatar
It could be heavy knock, that sounds kind of like misfire. Does it make any noise? If it is you might want to check your plugs and coils. GL
