Newb LC-1 issue, help please.
Old Jul 15, 2010 | 10:43 AM
PAdutch's Avatar
I recently purchased a 03 with an LC-1 wired into the ECU and has a tune. Not knowing what I know now, I didnt know what the red button was in my ash tray, so I pressed it. Obviously not good.
Took the car for a ride and no surprise it drove like ****. I then did some research and now know it is the calibration button for the LC-1. I proceeded to do a free air calibration thinking thats all it needed. Afterwards I still got an error code so I thought my sensor was toast. Installed a new sensor, calibrated it, and it is still not working correctly.
Sometimes when I turn the car on the led light will stay solid (like it should) for a while but after a little it will still flash. Im kinda lost at this point and looking for help. Is there a better way to reset the LC-1? I didnt check the grounds but it seemed to be working okay before I pressed the button so I assume they are okay.
Old Jul 15, 2010 | 11:31 AM
leecavturbo's Avatar
do a calibration as in a new install. i.e don;t use the button.
iirc you unplug the sensor then power up for 30secs etc its all in the quick startup guide
http://www.innovatemotorsports.com/s...Quickstart.pdf
Old Jul 15, 2010 | 12:00 PM
PAdutch's Avatar
Yeah i did all of the for new install. Unplug sensor from unit, power up for 20 secs, turn-off, connect sensor, warm up sensor, free air calibrate (push and hold button for 30 secs), reinstall O2.
Not rocket science and as far as I understand I need to free air calibrate which needs the button pushed.
Old Jul 15, 2010 | 12:38 PM
maybe who ever installed it set the output to some unstandard setting and made changes to the rom to suit
i.e the narrowband normally 0-1v and wide 0-5v
so you need to know what range your ecu is expecting and then set the output that goes to the ecu in lm manager to the correct scale
Old Jul 15, 2010 | 01:26 PM
PAdutch's Avatar
That wouldn't make the LC-1 show an error would it? Just make your car run like garbage.
Old Jul 15, 2010 | 02:13 PM
settings wouldn't make the lc1 show a problem but may make your car run like garbage as you said it is
Old Jul 16, 2010 | 05:39 AM
PAdutch's Avatar
Bump for some more ideas...
Old Jul 16, 2010 | 07:05 AM
you mention error code. what code was that?
Old Jul 16, 2010 | 07:18 AM
PAdutch's Avatar
The LED for the LC-1 is blinking, I believe error code 1.
Old Jul 16, 2010 | 07:43 AM
earlier when i said don't use the button, is because i had miss read the instruction and have recalibrated without doing the button bit at the end.
rightly or wrongly!
however when doing it my way it does recalibrate
you could try it ? have nothing to loose.
osetsky
Aug 20, 2014 04:23 AM
mirXa
Jul 21, 2010 05:00 PM
philr8
May 10, 2010 08:21 AM
Slick-IX
16
Apr 9, 2008 08:42 PM
Bster13
18
Mar 26, 2008 10:04 AM
