Input Output Sensor MPD?
hello.
I have a problem with my Evo VII LHD. I installed the Apexi Power FC and run the engine. But constantly shines the checks engine lamp. In the input output check shines the sensor MPD, can to me for one say which this for a sensor is?
in the guidance nothing is located from the sensor MPD.
Cheers Dani
Cheers Dani
If you have the boost control option enabled and you do not have the optional boost control selonoid plugged in, the check engine light will stay on all the time just as you described. To see if this is your problem, from the main menu go to ETC, function select, at the top of the menu there is a function called "Boost cntl". The enable/disable characters are in Japanese (I think), If you do not have the optional boost control kit the enable character should look somthing like this +=J , if you see somthing that looks like ,?j, use the arrow buttons to change it and that should clear up the check engine light.
The VII ECU is different than the VIII, unfortunately most people here are only familiar with the VIII.
Does the car run normally otherwise?
A US VIII will have some differences, I do not see any sensors listed as MPD, my system is an L-jetro. Is yours a L-jetro or D-jetro? MPD - Manifold Pressure Density? Just guessing.
Did you try to get support from APEXI or the Excel dealer you bought it from?
Hi Silver Surfer and WRC VII, I'd just installed the PFC on my VII too. If you guys don't mind, I've got a few queries........
I'm running on base map, 98 Ron, 1.5bar(21-22psi) of boost(HKS EVC V) and clock 40 knocks. Is this within the torelence limit? My check engine light did not flash at all. Injector clock a max value of 83% with a 255L fuel pump. And the EGT's max temp is 1100 degC. Are all this normal or am I running too lean?
My car is basically stock with a ARC Induction box, a 'operated' original exhaust and a Power Fuel Pump.
One thing I've noticed is that when I pull at 3rd gear, the rpm drops a little at around 4500-5000 before it starts pulling again.
Any advise?
Any advise?
1100* C is COOKING. Your definately lean. Keep it below 900* C.
1100C does seem way to high, under sustained high load the most I have ever seen is mid to low 900 C. I wonder if your EGT is reading correctly though because I would expect to see a much higher knock count if you were really running that lean at 1.5 bar. You should really put a wide band in and see what your A/F ratios are.
Although running the same boost and the 255L pump I am seeing mid/low 90's on my injector duty cycle when running past 7000 RPM at 1.5 bar. So maybe you are running that lean? For safety I run mid 11's to high 10's at 1.5 bar load (3.5K to 7.5K).
The PFC for the VIII comes pre-loaded with maps developed for the US market EVO (lower octane gas), so we may not be able to do a direct comparison. The base maps on the VIII PFC were actually to rich IMO (set for 91 oct, I can get 93), I wound up taking out about 5% accross the board.
I wonder if your ARC induction system is affecting your MAF sensor, you can compensate for this with the MAF sensor correction table, but you need to use a wide band first to see whats going on.
Thanks guys(especially Silver Surfer), for the input. Will have it tuned properly with a wide band. I was looking at the A/F Ratio on my Apexi TT(I know it's not accurate) and was hitting 10 at WOT. My EGT sensor is somewhere on the downpipe.
In the meantime, I'll just drive normally until I get it tuned.
Thanks again!
Cheers!!!
Thanks again!
Cheers!!!
If the sensor is some where on the down pipe perhaps that was 1100 Fahernheit not Celcius? Exhaust temps drop dramatically the further you are from the exhaust ports. Temps after the turbo can be 200-300C cooler, it does not seem possible that you were seeing 1100C that far down, not with your engine still running normally.
I would maybe throw the stock ECU back in an get some temp references.
It's Deg Celcius and not Fahernheit. Does that mean that I'm actually running 1300-1400C deg? Btw, I'm using Defi Link Display.
