cruising AFR
Old Mar 9, 2011 | 09:34 PM
lockadam2112's Avatar
cruising AFR
I wanted to know how far can I lean the 14.7 numbers on the ecu?
Old Mar 9, 2011 | 09:53 PM
tim85851's Avatar
heres what mine is set at...
Old Mar 9, 2011 | 09:56 PM
I wanted to know how lean can I go with the 5000rpm table up to 60% engine load
Old Mar 9, 2011 | 10:15 PM
tscompusa2's Avatar
depends on fuel.. also you need to force the car in open loop if you want it to use that area of the map for cruising, otherwise closed loop will take over and target 14.7
Old Mar 10, 2011 | 03:38 AM
Thanks for the info guys
EvoOtto
Oct 29, 2015 07:13 PM
reliablefr
18
Aug 30, 2012 11:46 PM
Melon
Feb 8, 2012 11:16 AM
NismoSkylineGTR
Nov 3, 2002 01:08 AM
