E-Manage Anti engine stall
I'm having problem with my car. How I should set the anti engine stall to prevent the engine to stall. What clamp value i have to add on the table below 500-1500 rpm. What throttle position should I set. Thanks
ALRIGHT!!!!!! Since know one knew, i took matters into my own hands.....i was messing with the AES, and i set it to 2% throttle position and set the clamp to 150 at 50 RPM's which i think is 500 but thats what my E01 reads......i gave the car hell with my SSQ bov VTA and the Car doesn't Stall!!!!!!! i idle a 1000 rpms which is about 170 higher than before but my Evo runs Perfect!!!!!!!!
Originally Posted by JustDSM
Do you have to be connected to the E-Manage to enable that function? I have the software only (read: no E-Manage) and am unable to activate that function. Its "grey-ed" out.
if you notice after you set the AES, your Service Engine light will come on.....i already went to the auto parts store a had it checked, the error code is p102 (mass air flow voltage..or something of that nature) i wouldn't worry too much about it, but i'll look more into it.
p.s. my car runs just as good now as it did with the stock bov
