Running a little rich.
Finally got my wideband installed yesterday. Car is running at WOT 10.6-11.1
Should I expect about a 10hp gain from leaning it out?
Or should I leave it where it's at? Car is 29PSI on 93oct
thats because , if you tune your car in summer time and you have a hot day , inlet temp is about 20 to 30 *Celsius , of its gets cold outside , the you can set the system på automaticly compensate , fore the cold air , with fule , so the engine wont spike ,
but if it is the opposit , and you tune your car when its cold and it get hot ,, outside in summer time , the management system cant handle that to compensate and you will spike the engine or hit a " boost " cut if you set that up ,
Tune the car in summer time ! nothing ealse
Chrushev
Nov 12, 2016 09:32 AM
riceball777
Dec 27, 2012 04:50 PM
