Evo 8 wandering afr when warm
Old Jan 18, 2012 | 08:37 AM
Evophil's Avatar
Exclamation Evo 8 wandering afr when warm
I have a 2005 evo with i/h/e, ets intercooler, and kelford 272 cams running 22 psi. Upon cold start up my afr's are spot on around 14.5 - 15.0, but when the engine heats up after a bit of driving i get a roaming idle sometimes going from around 12.0 to full lean, sometimes staying in the middle around 14.0-15.0. Does this sound purely like a tuning issue or are these the symptoms of a mechanical problem such as a vacuum/exhaust leak, etc? Any help would be greatly appreciated.
Old May 31, 2012 | 08:56 AM
connor4200's Avatar
i got same problem you fix it yet? seems like after my cosworth cams it started doin it
Old May 31, 2012 | 09:48 AM
AWDBus's Avatar
First test should be a boost leak test. These cars freak out with any leaks.
Gevo9
Mar 12, 2017 02:57 PM
GT45R Supra
Feb 14, 2017 05:16 PM
duranvw
Oct 19, 2016 11:36 AM
brusinn
Oct 1, 2013 04:41 PM
JorgeYaHeard
Sep 9, 2011 09:16 PM
