Aem failsafe tuning/ wiring
Old Sep 12, 2012 | 11:07 PM
karwh0re89's Avatar
I know by wiring into my rear o2 I will be able to log my a/f ratios, but my question is since the failsafe can log boost and has a wire to tap into map, can I wire it to the map and keep from having to buy a 4 bar? Or is that only or use with aems ems? Also to wire it is all I need to do is tap into either of the two wires on the boost solenoid for the failsafe option?
https://www.evolutionm.net/forums/au...gauge-aem.html
This link here shows him running a power wire to the opposite wire on his solenoid so it through me off...any info is greatly appreciated
Old Sep 13, 2012 | 01:57 AM
TheBoz's Avatar
You will need to install the Provided WB Sensor into the Rear Port.
You must log your AFR Before your Cat if you have one.
It comes with a boost line, so you need to tap into a booost line on your intake manifold for PSI
When the failsafe activates you can wire into just about anything that takes that signal. A boost controller is the best way to do it.
I have one in my car, and it works great. I love the new clips they have on the gauge, and it looks clean as hell in the dark.
Old Sep 13, 2012 | 03:26 AM
karwh0re89's Avatar
I already know pretty much all of what you said, the questions posted are what I needed answered, thanks for your input though
Old Sep 13, 2012 | 08:37 PM
karwh0re89's Avatar
Ttt
rado
AEM EMS
Oct 17, 2016 08:29 PM
alexis21
Feb 22, 2016 05:20 PM
johnnnyjeans
Evo X How Tos / Installations
Oct 8, 2013 02:50 AM
Andrew@AMS
Automotosports - Illinois
Sep 18, 2012 07:01 AM
lapulapu
Sep 9, 2008 05:52 PM
