arithmetic operation resulted in an overflow
Old Feb 28, 2014 | 03:00 AM
GeoMitsu's Avatar
Hello,
My ride is an Evo 9 2006 EDM, 88840017 tephra 5.5 rom.
I'm having a random check engine light on the instrument pannel (without any side effect), and when I plug the evoscan to do the DTC reading I get "arithmetic operation resulted in an overflow"
I reflash the ECU to get ride of it (by changing one parameter somewhere in the fuel map)
Does anyone knows the cause of this ????
Thanks in advance
Old Mar 11, 2014 | 03:28 AM
GeoMitsu's Avatar
Anyone for a suggestion or a probable solution .....
Old Mar 24, 2014 | 02:31 AM
GeoMitsu's Avatar
Is there anybody out there ?
Old Mar 24, 2014 | 03:35 AM
3K's Avatar
3K
Why don't you just scan the cel with a obd ll reader. That way no ones guessing what it could be.
Old Mar 24, 2014 | 03:41 AM
GeoMitsu's Avatar
Today I thought the same and scaned it with a OBD reader and It throwed P0170. (I'll deal with the fault later)
My problem is why can't I read the fault with evoscan , is it the car ecu that is saying goodbye or an evoscan issue ? ?
Thanks
Old Mar 24, 2014 | 03:56 AM
3K's Avatar
3K
Thanks
Yeah, I've never had any luck trying to read codes with evoscan either.
You should check for vac leaks or your 02 sensor for that code.
Good Luck
Old May 1, 2014 | 10:25 PM
superkizuna's Avatar
This just started happening with my evoscan too. I started using Scatech to check codes.
Old May 1, 2014 | 11:02 PM
Originally Posted by EvolutionBrian
get an ecu flash
not sure what you mean
Old Sep 20, 2016 | 09:36 AM
Ians06's Avatar
Back from the dead! Anyone solve this issue?
ShanesEVO
39
Apr 2, 2022 09:43 AM
chassis87
Dec 30, 2016 04:26 PM
TxFAkuma
Sep 14, 2016 02:40 PM
GotKT?
Jun 8, 2016 08:17 AM
brainwarped
Lancer Troubleshooting
May 25, 2016 10:44 AM
