here is my first datalog with UTEC!!
here is my first data log. Let the tuning begin. This is with the supplied map from TXS with my mods. Ime having a hard time holding boost. the EVC is fighting the POS BOV which i can hear sputtering. RRR
DATA1
, , , ,Load,Knock, , , Mod, Mod, , Mod, WB
RPM, MAP, MAF,TPS,Site,Count, Ign#1, Inj#1, Ign, Fuel,Boost, MAF, AFR
, psia, Hz, % , , , deg , duty , deg, % ,(OL) , Hz,
853,+27.4, 29, 0, 00, 00, +4.2, 1.0,ECU. , +0.0,ECU. , 29, 14.49
853,+27.4, 31, 0, 00, 00, +4.2, 1.0,ECU. , +0.0,ECU. , 29, 14.49
854,+27.4, 29, 0, 00, 00, +5.1, 1.0,ECU. , +0.0,ECU. , 29, 14.49
864,+27.4, 29, 0, 00, 00, +2.1, 1.0,ECU. , +0.0,ECU. , 29, 14.53
867,+27.4, 30, 0, 00, 00, +3.2, 1.0,ECU. , +0.0,ECU. , 29, 14.61
1876,+27.2, 89, 11, 00, 00, +28.2, 2.0,ECU. , +0.0,ECU. , 95, 14.37
1874,+27.2, 92, 11, 00, 00, +28.2, 3.0,ECU. , +0.0,ECU. , 101, 14.37
1881,+27.4, 154, 13, 00, 00, +31.3, 39.0,ECU. , +0.0,ECU. , 263, 14.65
1880,+27.4, 235, 46, 00, 00, +16.1, 8.0,ECU. , +0.0,ECU. , 203, 14.74
1953,+27.4, 221, 93, 10, 00, +15.1, 8.0,+14.6, +0.0,100.00, 267, 13.95
2000,+27.4, 283,100, 10, 00, +16.1, 8.0,+14.0, +0.0,100.00, 256, 13.39
2080,+27.4, 250,100, 10, 00, +14.4, 9.0,+13.6, +0.0,100.00, 280, 13.42
2136,+27.4, 261,100, 10, 00, +15.1, 10.0,+13.0, +0.0,100.00, 263, 13.42
2174,+27.4, 355,100, 10, 00, +14.4, 10.0,+12.6, +0.0,100.00, 337, 13.39
2246,+27.4, 304,100, 10, 00, +13.4, 11.0,+12.2, +0.0,100.00, 309, 13.33
2283,+27.4, 327,100, 10, 00, +14.5, 11.0,+11.9, +0.0,100.00, 356, 13.28
2342,+27.4, 392,100, 10, 00, +13.1, 12.0,+11.6, +0.0,100.00, 372, 13.25
2415,+27.4, 426,100, 10, 00, +13.1, 13.0,+11.4, +0.0,100.00, 375, 13.23
2495,+27.2, 361,100, 10, 00, +12.4, 14.0,+11.1, +0.0,100.00, 444, 13.23
2554,+27.2, 444,100, 10, 00, +11.4, 15.0,+10.9, +0.0,100.00, 372, 13.09
2635,+27.4, 399,100, 10, 00, +11.3, 16.0,+10.5, +0.0,100.00, 542, 12.93
2710,+27.4, 473,100, 10, 00, +10.0, 18.0,+10.3, +0.0,100.00, 503, 12.83
2787,+27.4, 414,100, 10, 00, +9.3, 18.0,+10.0, +0.0,100.00, 657, 12.67
2861,+27.2, 583,100, 10, 00, +7.5, 19.0,+10.0, +0.0,100.00, 647, 12.68
2949,+27.2, 519,100, 10, 00, +6.5, 22.0,+10.0, +0.0,100.00, 659, 12.81
3041,+27.2, 638,100, 10, 00, +4.3, 25.0,+10.0, +0.0,100.00, 793, 12.74
3121,+27.2, 931,100, 10, 00, +4.3, 29.0,+10.0, +0.0,100.00, 748, 12.45
3226,+27.4,1050,100, 20, 00, +3.8, 35.0,+10.0, +0.0,100.00,1116, 12.21
3360,+27.4,1131,100, 20, 00, +2.7, 39.0, +9.2, +0.0,100.00,1213, 12.09
3468,+27.4, 862,100, 30, 00, +2.0, 45.0, +9.1, +0.0,100.00,1237, 11.98
3639,+27.4,1385,100, 40, 16, -0.4, 48.0, +4.5, -1.0,100.00, 972, 11.92
3749,+27.2, 907,100, 40, 00, +0.4, 50.0, +4.0, -1.0,100.00,1453, 11.81
3875,+27.2,1420,100, 50, 00, -0.3, 52.0, +4.0, -1.0,100.00, 922, 11.77
3987,+27.2,1424,100, 60, 00, +0.0, 55.0, +4.0, -1.0,100.00,1420, 11.73
4120,+27.2,1265,100, 60, 00, +1.9, 55.0, +7.5, -1.0,100.00,1506, 11.68
4251,+27.4,1278,100, 70, 00, +1.9, 57.0, +7.1, -2.1,100.00,1366, 11.61
4403,+27.4,1351,100, 70, 00, +0.2, 59.0, +7.7, -2.7,100.00,1213, 11.58
4553,+27.2,1543,100, 70, 00, +0.9, 60.0, +8.0, -3.3,100.00,1381, 11.58
4694,+27.2,1533,100, 70, 00, +3.9, 59.0, +8.0, -3.7,100.00,1412, 11.62
4796,+27.2,1524,100, 70, 00, +3.3, 64.0, +8.4, -4.9,100.00,1533, 11.62
4952,+27.0,1552,100, 70, 00, +5.3, 64.0, +9.4, -6.4,100.00,1373, 11.62
5073,+27.2,1618,100, 80, 00, +5.4, 66.0, +9.0, -7.0,100.00,1315, 11.58
5200,+27.2,1639,100, 80, 00, +5.7, 67.0, +9.0, -7.3,100.00,1612, 11.58
5282,+27.4,1694,100, 80, 00, +3.8, 68.0, +9.1, -8.0,100.00,1436, 11.62
5428,+27.4,1661,100, 90, 00, +5.8, 70.0, +9.6, -9.3,100.00,1428, 11.61
5555,+27.2,1748,100, 90, 00, +6.2, 71.0,+10.0, -9.5,100.00,1552, 11.62
5668,+27.2,1754,100, 90, 00, +7.3, 73.0,+10.0,-10.0,100.00,1572, 11.65
5787,+27.2,1748,100,100, 00, +7.8, 76.0,+10.1, -9.2,100.00,1724, 11.65
5910,+27.2,1773,100,100, 00, +9.1, 77.0,+10.7, -9.7,100.00,1677, 11.58
6027,+27.4,1792,100,100, 00, +10.5, 80.0,+11.1,-10.0,100.00,1644, 11.45
6150,+27.4,1623,100,100, 00, +11.6, 80.0,+11.5,-10.0,100.00,1655, 11.34
6207,+27.4,1736,100,100, 00, +12.7, 81.0,+11.8,-10.0,100.00,1592, 11.28
6337,+27.2,1838,100,100, 00, +13.8, 83.0,+12.6,-10.0,100.00,1748, 11.27
6459,+27.4,1968,100,100, 00, +15.2, 83.0,+13.4,-10.0,100.00,1748, 11.24
6535,+27.2,1923,100,100, 00, +16.0, 84.0,+14.2,-10.2,100.00,1785, 11.24
6653,+27.2,1901,100,100, 00, +18.0, 84.0,+14.6,-10.6,100.00,1689, 11.27
6747,+27.2,1851,100,100, 00, +18.2, 85.0,+14.9,-11.0,100.00,1677, 11.27
6830,+27.2,1976,100,100, 00, +19.5, 85.0,+15.8,-11.0,100.00,1851, 11.28
6944,+27.2,2000,100,100, 00, +20.8, 87.0,+16.6,-11.0,100.00,1689, 11.27
7062,+27.0,2008,100,100, 00, +21.5, 89.0,+17.1,-11.0,100.00,1644, 11.23
7122,+27.0,1901,100,100, 00, +21.6, 89.0,+17.6,-11.0,100.00,1865, 11.18
7230,+27.0,1968,100,100, 00, +21.8, 89.0,+17.9,-11.0,100.00,1785, 11.17
7293,+27.2,1893,100,100, 00, +22.5, 89.0,+18.0,-11.0,100.00,1677, 11.14
7423,+27.2,1960,100,100, 00, +22.5, 90.0,+18.0,-11.0,100.00,1700, 11.12
7473,+27.4,2024,100,100, 00, +22.5, 90.0,+18.0,-11.0,100.00,1748, 11.11
7610,+27.4,2032,100,100, 00, +23.6, 90.0,+18.0,-11.0,100.00,1824, 11.05
7627,+27.4,1773,100,100, 00, +23.8, 22.0,+18.0,-11.0,100.00,1666, 11.01
7843,+27.4,1865,100,100, 00, +21.6, 77.0,+18.0,-11.0,100.00,1506, 11.23
7524,+27.4, 353, 13, 00, 02, +32.7, 15.0,ECU. , +0.0,ECU. , 309, 13.20
7473,+27.4, 69, 1, 00, 00, +38.7, 7.0,ECU. , +0.0,ECU. , 107, 19.83
6988,+27.2, 90, 0, 00, 00, +38.5, 7.0,ECU. , +0.0,ECU. , 110, 17.72
6485,+27.2, 69, 0, 00, 00, +38.5, 6.0,ECU. , +0.0,ECU. , 68, 14.25
6071,+27.2, 44, 0, 00, 00, +38.5, 6.0,ECU. , +0.0,ECU. , 48, 14.11
5659,+27.2, 34, 0, 00, 00, +38.2, 6.0,ECU. , +0.0,ECU. , 37, 13.68
5265,+27.2, 52, 0, 00, 00, +38.2, 5.0,ECU. , +0.0,ECU. , 46, 13.28
DATA1
I'd like you to then add a little bit of fuel in the section I quoted above. Add .3 or so in the fuel map in those 10-40% load sites and let me see the changes. Actually looking at the map, the whole thing could use a little bit of fuel up to about 6k. Try small changes such as .5 at a time until that section is running a consistent 11.5:1. Then try leaning out the top end a little to around 11.2:1.
It makes this SO much easier since you have the tuner.
Thanks,
-Nathan
o.k. when you are telling me the whole thing could use a little fuel to 6K, do you want me to ad .5 to all load sites up to 6K or what. If ime not sure what you mean, ill wait till i understand. I cant afford to screw somthing up. RRR
Originally posted by rraulston
o.k. here i go. Can you tell me why you want me to pull the timing??? What are you seeing that is telling you that?? RRR
Now for your second question
Once you get that section of the map right at or below 11.5:1 you can start leaning out the higher RPM load sites a little bit at a time.
o.k. here is the next run. It looks like i went leaner. I added .3 lile you said to the fuel and took out the timing. This is not with the add .5 fuel throught the map. Now if it says -1 and i sub.3 then its -.7 right. This is alot to learn.......
830,+27.4, 29, 0, 00, 00, +5.2, 1.0,ECU. , +0.0,ECU. , 31, 14.58
830,+27.4, 29, 0, 00, 00, +5.2, 1.0,ECU. , +0.0,ECU. , 30, 14.58
835,+27.4, 29, 0, 00, 00, +4.2, 1.0,ECU. , +0.0,ECU. , 31, 14.58
836,+27.2, 29, 0, 00, 00, +4.3, 1.0,ECU. , +0.0,ECU. , 29, 14.61
836,+27.2, 31, 0, 00, 00, +3.2, 1.0,ECU. , +0.0,ECU. , 30, 14.74
839,+27.2, 29, 0, 00, 00, +3.2, 1.0,ECU. , +0.0,ECU. , 29, 14.83
3141,+27.2, 751,100, 30, 00, +6.5, 27.0, +9.0, +0.1,100.00, 862, 12.27
3135,+27.2, 796,100, 10, 00, +6.6, 28.0, +9.0, +0.1,100.00, 880, 12.27
3264,+27.2, 894,100, 10, 00, +5.6, 33.0, +9.0, +0.3,100.00, 880, 12.17
3404,+27.0,1020,100, 20, 00, +4.2, 40.0, +8.0, +0.3,100.00, 929, 12.05
3516,+27.0,1259,100, 30, 00, +3.8, 45.0, +8.0, +0.3,100.00, 976, 12.00
3654,+27.2,1366,100, 60, 00, +2.6, 50.0, +7.0, -1.0,100.00,1184, 11.92
3775,+27.2,1008,100, 50, 00, +2.9, 51.0, +7.0, -1.0,100.00,1256, 11.84
3958,+27.2, 974,100, 50, 00, +4.1, 54.0, +7.0, -1.0,100.00,1420, 11.81
4095,+27.2,1333,100, 50, 00, +5.7, 55.0, +7.0, -1.0,100.00,1428, 11.73
4257,+27.2,1488,100, 50, 00, +5.7, 56.0, +7.0, -1.2,100.00,1329, 11.56
4403,+27.2,1269,100, 50, 00, +5.7, 57.0, +7.5, -2.0,100.00,1225, 11.53
4510,+27.4,1358,100, 60, 00, +5.8, 57.0, +8.0, -3.2,100.00,1037, 11.58
4688,+27.4,1412,100, 60, 00, +6.9, 60.0, +8.0, -4.6,100.00,1373, 11.58
4830,+27.2,1355,100, 70, 00, +7.0, 62.0, +8.4, -4.9,100.00,1524, 11.58
4952,+27.2,1587,100, 70, 00, +8.0, 64.0, +9.6, -6.7,100.00,1173, 11.56
5081,+27.0,1607,100, 70, 00, +9.0, 64.0,+10.0, -7.1,100.00,1506, 11.58
5249,+27.2,1436,100, 80, 00, +8.8, 66.0, +9.0, -7.3,100.00,1428, 11.67
5359,+27.0,1572,100, 80, 00, +7.9, 67.0, +9.4, -8.2,100.00,1470, 11.71
5473,+27.2,1572,100, 90, 00, +9.1, 69.0, +9.9, -9.3,100.00,1461, 11.71
5611,+27.2,1628,100, 90, 00, +9.9, 71.0,+10.0, -9.8,100.00,1404, 11.73
5727,+27.0,1858,100, 90, 00, +10.2, 73.0,+10.0,-10.3,100.00,1497, 11.71
5858,+27.2,1672,100, 90, 00, +12.3, 74.0,+10.8,-10.7,100.00,1612, 11.62
5984,+27.0,1915,100,100, 00, +13.2, 75.0,+10.9, -9.9,100.00,1515, 11.58
6082,+27.0,1824,100,100, 00, +13.4, 77.0,+11.4,-10.0,100.00,1592, 11.53
6207,+27.0,1945,100,100, 00, +14.3, 78.0,+11.8,-10.0,100.00,1592, 11.43
6313,+27.0,1700,100,100, 00, +14.3, 80.0,+12.6,-10.0,100.00,1644, 11.37
6435,+27.0,1872,100,100, 00, +16.2, 80.0,+13.4,-10.0,100.00,1666, 11.33
6535,+27.2,1915,100,100, 00, +17.2, 82.0,+14.1,-10.1,100.00,1666, 11.30
6640,+27.2,1818,100,100, 00, +18.6, 82.0,+14.6,-10.6,100.00,1798, 11.27
6747,+27.2,1886,100,100, 00, +18.4, 82.0,+15.0,-11.0,100.00,1633, 11.18
6858,+27.2,1831,100,100, 00, +20.5, 84.0,+15.8,-11.0,100.00,1724, 11.17
6944,+27.2,1811,100,100, 00, +21.6, 84.0,+16.6,-11.0,100.00,1773, 11.14
7032,+27.2,2024,100,100, 00, +21.8, 87.0,+17.2,-11.0,100.00,1712, 11.11
7137,+27.2,1886,100,100, 00, +22.5, 88.0,+17.6,-11.0,100.00,1592, 11.05
7230,+26.8,2057,100,100, 00, +22.5, 88.0,+17.9,-11.0,100.00,1623, 10.96
7326,+26.6,1818,100,100, 00, +22.5, 88.0,+18.0,-11.0,100.00,1724, 10.96
7423,+26.6,1805,100,100, 00, +22.6, 90.0,+18.0,-11.0,100.00,1644, 10.99
7524,+26.6,1953,100,100, 00, +23.7, 89.0,+18.0,-11.0,100.00,1655, 10.96
7575,+27.0,1923,100,100, 00, +23.7, 88.0,+18.0,-11.0,100.00,1677, 10.93
7524,+27.0,1968,100,100, 00, +23.5, 87.0,+18.0,-11.0,100.00,1785, 10.90
7541,+27.2,1628,100,100, 00, +23.0, 79.0,+18.0,-11.0,100.00,1562, 11.65
7627,+27.2, 236, 1, 00, 03, +31.9, 13.0,ECU. , +0.0,ECU. , 336, 14.61
Oops.. Brain fart.. Yes, if the value is -1 then it should be -.7
The more positive the number, the richer the car runs.. I just realized your running a buschur exhaust and aftermarket filter, the same combo as mine.. the areas where your lean are due to the MAF sensor misreading.. you may actually need to dip into positive numbers in that region.. on my S-AFC (Now sitting in a box..
) you'd typically bump the fuel +1 or +2 in the area where you hit peak boost.. you may actually see the need to hit +1 before you get a safe AFR
Fortunately the default maps they gave us have pretty conservative timing.. you might want to get the EGT sensor if you plan on playing with the timing.. Even without detonation or an overly lean mixture, aggressive timing could cause very high EGT's
If you haven't already done this, get one step cooler plugs.. If you haven't noticed with the Buschur exhaust, even without boost control modifications it is about 20 or 21psi... Thats part of the reason the STG1 Utec map is a little lean in that RPM range and why your getting a little detonation.
) you'd typically bump the fuel +1 or +2 in the area where you hit peak boost.. you may actually see the need to hit +1 before you get a safe AFRFortunately the default maps they gave us have pretty conservative timing.. you might want to get the EGT sensor if you plan on playing with the timing.. Even without detonation or an overly lean mixture, aggressive timing could cause very high EGT's
The advantage of the UTEC is the load points.. When I found there are lean spots with the s-afc, its typically when I'm not quite at WOT and get full boost, it results in a somewhat lean condition.. this is something we can now tune around with the UTEC..
by pulling the timing like i was told, seemed to clear up the knock count. But i went from -1 to -.7 and it shows leaner. Ill call them tommarrow and make sure before i do another run.....
