Logged a fuel cut condition
Old Oct 8, 2015 | 04:26 PM
absolut525's Avatar
Hello all,
I finally got around to running my first log with my Evo IX. I am still trying to make heads or tails of everthing im reading so bare with me please. I captured the log during what I believe is a fuel cut condition and I was wondering if the log could help determine the issue.
Log is attached. I did notice timing jump from -4 to 20 in the logs.
TPS RPM TimingAdv
100 4718.75 -4
100 4718.75 -4
100 4625 -4
100 4656.25 20
100 5343.75 3
100 4718.75 -4
99.2 4875 -4
I appreciate any ideas on this.
*edit* I should mention mods although the car has occasionally hit fuel cut since I first owned it.
Buschur TBE
Omni 4 Bar
Innovate LC-2 Wideband
90 Octane (Alaska's premium)
-Dave
Old Oct 11, 2015 | 10:06 AM
CDrinkH2O's Avatar
Fuel cut is a possibility, but without a WBO2 or IPW log it is impossible to say. Also why is Load1B not logging?
Old Oct 15, 2015 | 10:32 AM
absolut525's Avatar
I will be running another log here shortly with my wideband. Im not sure about load1Byte as far as I know I had it selected. I do not want to keep running logs of fuel cuts because I imagine its not too healthy for the engine.
Old Oct 15, 2015 | 05:56 PM
absolut525's Avatar
Cleaned up my intercooler piping connections and I believe I fixed a boost leak. The ends of the stock aluminum piping had some corrosion build up. I won't know for sure until I hook up my leak tester this weekend but I ran another log today with the MAP sensor and wideband correctly configured (at least I believe they are). The car did not hit a fuel cut but the boost spiked to 27.9psi and tapered off to around 19-22. This is on a stock rom that was modified only for the OMNI 4 bar. Although the car felt great I was curious if anyone sees any issues in the log besides the boost spike?
When I select Load1B in Evo-scan it mentions that it is only available with tephra v7. So I ticked Load11Bit4 because it was the only option giving me a readout.
redSLed
Jan 9, 2017 05:22 PM
Thugline
17
Apr 26, 2010 04:42 AM
eastxcelerate
Mar 19, 2009 07:33 PM
Trustz
Sep 13, 2003 09:16 AM
ADMstunna
Apr 28, 2003 11:02 AM
