no zip zero none nada immobilizer code wth
Old Jan 30, 2016 | 11:18 AM
Cbr1000love's Avatar
first off hello everyone
ok so i pulled my rom and my first problem was that i couldnt open it properly because a previous tuner switched the rom id from a 94170015 to 9410715v7(i believe because thats the one that matched the rom internal id i pulled minus the v7, but my cel flashes for knock so its my best guess)
everyone says to grab the immobilizer code first for safety right off the bat. so when i look threw the meta and go to IM code it says 00000. is it possible that the previous tuner just deleted it?
also i looked up as much as i could on this and the closest thing i could find is this forum but it applys to a evoX not a 03.
https://www.evolutionm.net/forums/ev...izer-code.html
Old Jan 30, 2016 | 11:28 AM
ok so 1 min after posting this i thought of a awesome test to see if i do have a immobilizer code. i have 2 cut keys but when i went to get them programmed the key place said there computer couldn't read my cars ecu. i just went out and my car started right up with the cut key that wasnt programmed for it.
for me this is a good thing i guess because when i bought the car i only got one key. now i have 3 working keys. and i didnt have to pay $60 to get the second one programmed.. also i dont live in the ghetto and i have plenty of guns so im not worried about someone trying to steal it
Old Jan 30, 2016 | 05:26 PM
<table name="Immobilizer" category="Miscellaneous" address="3ffce" type="1D" level="3" scaling="Hex16"/>
<table name="Immobilizer Hex" category="Miscellaneous" address="ffa" type="2D" level="2" scaling="Hex16">
<table type="Static Y Axis" elements="1">
0x0040 for 2003 or 0x0055 for 2004 or 0x0058 for 2005 USDM - 0x004D for EDM:
</table>
</table>
<table name="Init Code" category="Miscellaneous" address="3ffcc" type="1D" level="2" scaling="Hex16"/>
<table name="ECU Internal ID" category="Miscellaneous" address="f52" type="2D" level="3" scaling="Hex8">
<table name="Byte Position" type="Static X Axis" elements="4">
b1
b2
b3
b4
</table>
</table>
found this patch in v7 that must be why. right now patches aka xml code arnt showing right now so i dought you can see it but here we go it it will help anyone
Old Jan 30, 2016 | 05:27 PM
yup because of problems with evolutionm its not showing.. im haveing that problem with a different code i need right now
EVO8speed
Jul 10, 2010 12:26 AM
thepernicious1
Nov 29, 2007 08:59 PM
Mr.MR
Jan 20, 2006 04:00 PM
