Omni 4 Bar on Evo 9
Omni 4 Bar on Evo 9
Good day!
I have searched high and low for info in on the scaling for an OMNI 4 bar on my Evo. I can't seem to find the info for ROM ID 88590715. Do I just run the Tephra ROM and XML with the JDM sensor and change the scaling? Or is the mod specifically set up for the MAP sensor?
Any help would be grateful. BTW I have figured a lot out by searching but I can't figure this out.
Thanks!
Thanks!
So I think you can use this link https://redirect.viglink.com/?format...t&txt=Download
More info and where I found it is from here https://www.evolutionm.net/forums/ec...hramod-v7.html
I hope that helps!
I hope that helps!
cplillges (Apr 21, 2017)
Thanks man! I'll give this a try and see where I end up. I am trying to get back into the swing of tuning. It's been awhile. I saw that post but it makes reference to the JDM 3 bar. I didn't know if I could use that if I just changed the scaling.
rr06rs
Jun 13, 2012 07:01 PM
magyar86
Nov 23, 2010 08:12 AM
GregGSC
Evo 'For Sale' Electronics / Lighting / Audio
Jul 1, 2009 09:27 PM
