Evo 8 cams
Evo 8 cams
Hello,
Is there anyone could help me with evo 8 stock cams specs? I just istalled a EMU Black and I can t fine tune the injection angle. I tryied to adjust at idle for example at the richest AFR point, I m using end of injection by the way and the angle is 320 at the angle table for idle. I was expecting for 400 -430. At 320 where is the richest point means the injector closes 40 degrees before TDC. Stock cams as I saw on different forumus must be fully closed 50* ATDC. Am I right? Thank you
Thank you 🖒😊. Now the inj angle I just set it yesterday make sense and based on this info I could fine tune until max boost. Thank you again
Gary@MellonRacing
Evo 'For Sale' Engine Internals and Drivetrain
Sep 25, 2010 04:01 PM
