FIC 2150’s with higher base pressures
Wondering if anyone has run 2150’s with increased base pressure on e85?
im thinking somewhere around 55~60 psi on e85 is doable. If anyone has info it would be appreciated. My fuel system should flow enough for 1000hp @ 110psi rail pressure that’s why I ask.
Biggest thing is, can your pumps handle it the pressure and flow enough?
Usually a bump in base pressure doesn't effect idle fueling too much. The increased pressure actually makes it take longer for the injector to open, reduce the amount of fuel you get for a given pulse width. So, it won't hurt to try.
Bump for some real world testing. Plenty of fuel I have dual aem 044’s. Wondering if I can get the idle afr’s in the 12’s with a base pressure of 55 psi?
TommiM
Feb 7, 2013 11:53 AM
EAVWIDL
Jul 29, 2011 09:53 AM
