1500 rpm rich condition
This happens only in open loop. Closed loop it doesn’t do it. I can’t run closed loop because no matter what I do the lean tip in on take off is there and I almost got hit the other day because of it so decided to run open loop. On open loop everything is fine but I just have this little issue. I’ll check out the adjustment you made jmedina and get a longer log just cruising going through the gears.
now, I run 9417 and it seems like every time I turn on the car it does something different...I’ve heard of this happening with 9417. I was also thinking of switching to 9653 but that’s another story. Would like to get this issue sorted out.
I know with the lean tip in thing I tried everything. I even tried making map ve 1:1 and tps/Accel tables rich as hell and it would do it randomly. That’s the worst part that it’s random not consistent. For now I want to try and figure it out the open loop issue. Not home now but I’ll post logs later.
Jmedina, you did something in this rom besides changing map ve and rpm ve that fixed this issue. Actually now it goes lean instead of rich around that rpm but i can work with that. I tried to richen it up a little bit at that same rpm but through rpm ve nothing happens. Can you please tell me what you did so i dont have to go searching and compare both roms? I put your ve settings into my rom and the issue still happened. I also noticed on map ve at 70 kpa you raised it to 64 load from 60 why? I will post driving logs later with the changes.
edit - i just realized you enabled all stutter options...no way this is what fixed it...
Ok bud, will do. Would love to meet up some time and compare notes. I dont understand why enabling all stutter fixes resolved the issue. I tried disabling the fix i was using but that didnt do it. I didnt think of that lol. Here is a log cruising like i promised. By the way, thank you. Ive been chasing this for a while.
Thx man. I’ll ask this question here so I don’t make a new thread. I installed a sparktech cop and car went from 11.3 at wot to 11.7 - 11.8. Can cop cause this because of better spark? Problem is I can’t richen it up because idc is at 110% in some spots ...stock injectors. Just trying to figure out if cop can cause this
