Throwing a P0122 code. Losing throttle response. Hlp.
Old Mar 1, 2019 | 04:44 PM
Womb Raider's Avatar
Veteran: Marine Corp
Hey guys! Throwing that code and also losing throttle response at about 3k rpms. It’ll frequently go past it but will lose throttle response again almost immediately. I installed an aem 3.5 bar map sensor before this happened. Worked fine, threw a map code but didn’t have issues until recently. The car runs fine when I unplug the map sensor. I would just have to grandpa it.
Any ideas?
Old Mar 1, 2019 | 07:47 PM
Heres a thread where the same TPS code was thrown but was a faulty MAP sensor
Is that a new sensor you installed? Can you load the old sensor back in & check that?
https://www.evolutionm.net/forums/ev...ap-sensor.html
Old Mar 1, 2019 | 07:52 PM
kaj's Avatar
kaj
I assume the car is tuned for that MAP sensor?
Old Mar 1, 2019 | 09:21 PM
its not tuned for the sensor yet. Im getting the evo ready to be put on a standalone ecu. I drove it 1000+ miles with that map w/o any issues.
Old Mar 1, 2019 | 09:22 PM
yes new sensor. I can, just gonna have to do some wiring
Old Mar 2, 2019 | 05:41 AM
Thanks for the relocation evom 🤟🏽
Old Mar 2, 2019 | 05:57 AM
Hopefully some of the Gurus can help you solve this
Old Mar 2, 2019 | 07:57 AM
Forgot to add, When I was messing with the AEM EMS ecu at full open throttle my tps was at like 3.0 volts. Think they’re supposed to be at 5 V?
Old Mar 4, 2019 | 04:30 AM
My CEL eventually turned off, still having the same issues though
Old Mar 10, 2019 | 03:01 PM
Figured it out. Wiring was incorrect to my map sensor.
