Vipec Idle trouble.
Vipec Idle trouble.
I am having one hell of a time getting the idle to stop surging, hanging, and wandering all over the place. Im using about 60 steps from full open , in open loop and all trims are zeroed. Idle afr is approximately 13, ignition timing is 5°. Target idle rpm is 1100. IAC appears to behave normal when Key on engine off and the iac removed.
Specs on the car
2.4 LR 9:1
S2 CAMS
GTX3582 G2
Any suggestions how to calibrate idle correctly here?
Specs on the car
2.4 LR 9:1
S2 CAMS
GTX3582 G2
