Pops and Bangs Evo 6 ecu
Old Jan 22, 2022 | 03:37 PM
Rick2020's Avatar
5 Year Member
I've added the pin 44 and grounded the other wire.
I've set ignition retard to -10 and added fuel I've changed afr to 12 I've only done this to 3000rpm and 5000rpm across ignition tables and fuel tables.
I believe I only alter the secondary fuel and ignition table. Do I change the low octane table table in the secondary table to?
Also I'm on ceddy mods
Kind regards
Old Feb 13, 2022 | 08:20 AM
jetjockeyjosh's Avatar
Kind regards
No you don’t need to change the secondary unless you also want pops and bangs when you switch to your other map. I have mine set up to be quiet and good on gas normally, flip the switch for more power, pops and bangs.
Old Feb 13, 2022 | 09:51 AM
Rick2020's Avatar
5 Year Member
Do you have the sas system
Old Feb 13, 2022 | 06:47 PM
Yes I do. 3 inch exhaust, cat delete as well. You may need to tweak your SAS settings. I still need to dial mine in as I usually get just one big pop without much burble.
Old Feb 13, 2022 | 07:10 PM
Rick2020's Avatar
5 Year Member
QUOTEThis is where my problem is then. I don't have sas
Old Feb 13, 2022 | 09:56 PM
Yeah I’ve heard you can’t get it as easily without the SAS installed. You should still be able to but it’s will require some more work. I would imagine tweaking the timing and AFR on over run. So, high rpm with low load. Although I have heard that the ECU is “locked” to a maximum of -5 degrees of timing. I haven’t messed with it myself so there may be a workaround. Good luck.
Old Feb 13, 2022 | 10:04 PM
Rick2020's Avatar
5 Year Member
Oh well
confuzion
Mar 14, 2016 09:16 PM
r4p.t0x
Jun 1, 2012 02:44 PM
foxbat
Aug 16, 2010 05:13 PM
chmodlf
Feb 15, 2010 04:36 PM
